stored fuel eats up tank filter? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
 4Likes
post #1 of 12 (permalink) Old 06-17-2019, 02:01 PM Thread Starter
Stored Rancher 420 for 5 years with fuel in tank, (my bad) no start going through fuel system, new parts etc. found filter in fuel tank half gone. Not sure of last fuel but was most likely E10. Photo of filter attached, anyone else seen this?
180pilot is offline
post #2 of 12 (permalink) Old 06-17-2019, 02:47 PM
harig's Avatar
Garage
that corn does it every time....pure gas is all i use now.
Moccasin Ranger likes this.
harig is offline
post #3 of 12 (permalink) Old 06-17-2019, 03:03 PM
jeepwm69's Avatar
Garage
You'll be lucky if it doesn't seize up your fuel pump as well.
2005 Foreman Rubicon Camo
Perfex, 27" Mudbugs
5K Viper Max winch
2009 Foreman 500FM Green
Perfex with HL springs
27" Execs on Rubicon rims
Heated Grips and Thumb, HID's
4K Viper Max winch
2006 Foreman 500FM Green
3K Superwinch winch
2009 475 Rancher AT Tan
26" Mudbugs on Rincon rims
jeepwm69 is offline
post #4 of 12 (permalink) Old 06-17-2019, 07:16 PM
mrbb's Avatar
have to remember that water can get into fuel and your tank in many ways, and the water in it will rust things out like that too!
I am NOT a fan of ethanol fuel., period, but there is more ways to have things go bad than just ethanol fuel in tank!
condensation can happen with pure fuel too over that long a time period if exposed to temp swings!
or just bad fuel at station, many stations have been known here to sell BAD fuel
leaking holding tanks, all this rain any more, flooding and so on??
never know LOL
when storing for long amounts of time, you really need to do prep work to ensure things last as best they can!
mrbb is offline
post #5 of 12 (permalink) Old 06-18-2019, 08:46 AM
Honda Lover
mrbb pretty much took the words right out of my keyboard. Condensation, temperature swings, .... sweat! My street bike has the most finicky carbs ever built, seafoam is my friend. Corny gas eats materials and I've read that it is hydroscopic, absorbs moisture. And then there's the goop it leaves behind, which sets up like concrete.
Condensation - Sometimes I can walk into the garage and everything looks like it was misted with a spray bottle, same conditions exist inside fuel tanks/cans.
There's a process to remove ethanol from gas, it involves adding water and letting it settle, same thing happens with condensation in your tanks and cans. Now imagine 100% ethanol soaking on your carb parts, fuel tank, etc.
I've been attacked by the corn lobby for my comments about ethanol. So a pic is worth 1000 words. This is some year-old weedeater gas. Look at the bottom.
Moccasin Ranger is offline
post #6 of 12 (permalink) Old 06-18-2019, 08:58 AM
Honda Lover
Been using Seafoam in my gas as needed, or twice a year, and for storage. Don't know if it stops the damage, but it does keep the carb jets open.
post #7 of 12 (permalink) Old 06-18-2019, 10:36 PM Thread Starter
Working on it.
Most damage done by the Olefines in fuel that left "molasses" in tank and pump enclosure, completely clogging the old design filter on bottom. Ordered all new pump for $88 even though it still "buzzed". New pump has filter on the side. But, it seems dumb they did not put a drain on the bottom of the pump enclosure to drain out any water, etc. Going to drill and tap a drain valve into the enclosure bottom. Have to modify the pump's bottom support for the drain. Still cannot figure what Honda used for the tank pickup filter that got ate up??? I've always seen stainless steel mesh used in that role. Still have to borescope the tank to see how much molasses are in there. Being it's black, hard to see. I find denatured alcohol will solvent it quickly. Might need a steel shot and alcohol tumble to remove any left in there.
Going to try Chevrons's new fuel treatment for small engines, claim is 2 yr storage. Got last bottle at Auto Zone, seems to be selling fast. With a drain in bottom of the pump enclosure, the lowest point in system, I will be able to check for and drain out any water etc. Will only store with tank full from now on. And, will now be using it more often..
180pilot is offline
post #8 of 12 (permalink) Old 06-19-2019, 06:42 PM
JeffinTD's Avatar
Yeah ethanol contamination will do that. I’d replace that part and possibly the fuel pump.
If you can get non eth gas, I run that exclusively. If it’s hard to find, I’d at least try to fill it with non-eth prior to storage. Having the tank full gives less surface for condensation, and less of the gas is exposed to air, which delays the gas from going bad.
If I’m not using a machine for an extended period, I’ll siphon the gas into a jug to use in a car and replace the gas in the machine at least annually.
Having clean oil is also a good idea for storage.
06 Rincon 680. Foreman headlight conversion, Guru bumper, Warn XT30, Maier guards, Bighorns
05 Foreman 500 FM, 2.5 Warn, Bighorns
Dually Ram and Patio Hauler 5th wheel
JeffinTD is offline
post #9 of 12 (permalink) Old 06-21-2019, 11:05 PM Thread Starter
Anyone know why my replys never get posted, they just disapear after a message saying the administrator will have to approve??????
180pilot is offline
post #10 of 12 (permalink) Old 06-22-2019, 11:35 AM
Administrator
toodeep's Avatar
Garage
Quote:
Your email or user name put you into a moderation. In 5 post or so you'll be good to go. I'll try to get them all approved as soon as possible for you.
2013 MUV 700----2011TRX500FPM----2009TRX420FPA----2009TRX420FA----2007 TRX420FM----2006 TRX400FA----1995TRX300FW----1988TRX350D----1988TRX300---1974 CB750 Amen Savior Chopper----!974 ST90
toodeep is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
