TRX350 Rancher carb issue - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 5 (permalink) Old 12-18-2018, 11:12 AM Thread Starter
Hi all,
Picked up a 2003 Rancher ES with a 'leaking out the carb bowl drain line' issue. So I got the carb out, cleaned it, tossed in a rebuild kit, buttoned it all back up and it runs like a champ. But it's still draining fuel out the overflow tube not 10 minutes after I got it all back together. Doh!
I replaced the needle valve, checked/cleaned the passage way and it appeared to be clear. That only leaves the float itself and as it's non-adjustable - would that likely be the culprit? Best I can tell it's the original float/internals based on the 'pop' of the screws when I disassembled sounding like they've never been off in it's life.
I'm thinking the float has a pinhole in it thus fills up and sinks thereby opening up the needle valve.
Is that where you would go next? Replace the float? Get a cheap Amazon replacement carb?
Thanks!
M38A1 is offline
post #2 of 5 (permalink) Old 12-18-2018, 11:59 AM
Honda Lover
That's where I was headed, especially with the 10 minute time span. I got in the habit of shaking floats to see if there's gas inside, or submerge, rotate, and look for bubbles. Plastic floats may be easier to patch, versus soldering a brass one. Ebay could have a float also.
Could be dirt moving in the fuel, cleaned mine three times in row, even with two fuel filters. One filter was full of rust and broken inside. You'll know when you open the carb again.
Check the overflow tube inside the carb, they're known to crack. A small crack may not open up until it warms up.
Moccasin Ranger is offline
post #3 of 5 (permalink) Old 12-18-2018, 12:04 PM Thread Starter
Thanks for the input.
To add insult to injury, the petcock doesn't fully close either. Argh.... Had to roll it out of the garage last night just to keep the stink factor down.
Where's the fuel filter? In the tank?
M38A1 is offline
post #4 of 5 (permalink) Old 12-19-2018, 03:34 PM
jeepwm69's Avatar
Garage
Most likely the seat in the carb needs to be polished.
What I did on my 350 projects is add a cheap inline shutoff valve to the line between the tank and carb. Replacement petcocks are pricey.
To the carb, for some reason the 350 Rancher carbs are horrible about leaking. If your float is good, take a qtip and put some polishing compound on it, or even toothpaste, chuck it in a drill, and on low speed polish the seat in the carb. I also usually scuff the rubber tip on a needle valve with some emery cloth or steel wool.
If that doesn't work, get a tiny polishing stone from a dremel kit, with a conical end. Grind the stone down on the sides where it will fit up in the seat, and USING YOUR HAND, turn it back and forth a few times to really polish the seat well, where there's a perfectly smooth, clean surface for that needle to seat.
If that doesn't work, buy a new carb. Don't get aftermarket Chinese crap. Get an OEM carb, preferably new, because if you get used it will probably have the same issues as the one you have.
2005 Foreman Rubicon Camo
Perfex, 27" Mudbugs
5K Viper Max winch
2009 Foreman 500FM Green
Perfex with HL springs
27" Execs on Rubicon rims
Heated Grips and Thumb, HID's
4K Viper Max winch
2006 Foreman 500FM Green
3K Superwinch winch
2009 475 Rancher AT Tan
26" Mudbugs on Rincon rims
jeepwm69 is offline
post #5 of 5 (permalink) Old 01-06-2019, 06:57 PM
I'll second the q-tip in a drill to polish the brass seat the needle goes in. I've had to to it to several carbs to fix them.
rocketman5144 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
2007 rancher 400 carb issue? jonny23 Honda Rancher 350, 400 & 420 0 07-23-2012 08:51 PM
Just purchased 2002 TRX350 Rancher, shifting question Turboz Honda Rancher 350, 400 & 420 13 06-10-2011 12:01 AM
86 trx350 fourtrax carb troubles move Vintage Honda 3 04-04-2011 05:21 PM
Trx350 fe rancher shifting problems JOHN P Foreman 500 0 03-28-2011 03:08 PM
Carb Issue or Clutch Issue???HELP PLZ C1iffburton Foreman 500 8 11-05-2007 10:07 AM
You may post new threads
You may post replies
