Help with Carb Removal - Page 2 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #11 of 19 (permalink) Old 12-19-2010, 08:00 PM
Administrator
toodeep's Avatar
Garage
This is a 450 carb but very similar to yours. The needle jet is the piece I'm speaking of.
1987 350D (work in progress)
toodeep is offline
post #12 of 19 (permalink) Old 12-19-2010, 08:30 PM Thread Starter
Yea the "needle jet" right above the "needle jet holder" (seat.. right?) is not in there. It must have fallen out, I did not realize it was even in there. Going to try and order a needle kit at dealer tomorrow.
07 Foreman 500
jamnjeep is offline
post #13 of 19 (permalink) Old 12-21-2010, 08:50 PM Thread Starter
Part came in today, installed and the Foreman is running great. Thanks for everyones help!!
I had some time today to ride it a little, put a few miles on it. One problem I have noticed though. It is very hard to get into 1st gear and reverse from neutral. I have to rock the atv back and forth to get it into either gear. Once in first it shifts great through the gears. Also its diffucult to get from 1st to neutral. Do you think this because its been sitting for so long (almost 2 years) or because its basically new (19 mile now) and needs to break in or is this a sign I have the 1st gear issue that some of the Foremans have??
Again thanks for the help!
07 Foreman 500
jamnjeep is offline
post #14 of 19 (permalink) Old 12-21-2010, 11:32 PM
Administrator
toodeep's Avatar
Garage
Try adjusting the clutch or it could be the idle is set too high or low.
toodeep is offline
post #15 of 19 (permalink) Old 12-21-2010, 11:34 PM Thread Starter
It seems to idle pretty low. Would two low an idle cause the problem? I will have to play around with the idle some and see what happens.
07 Foreman 500
jamnjeep is offline
post #16 of 19 (permalink) Old 12-21-2010, 11:37 PM
Administrator
toodeep's Avatar
Garage
You need the gears turning for it to shift good. Even though they are not engaged they are still turning with the oil friction. Too low of an idle they will be turning slower so the dogs on the gears will not mesh quite right giving a hard shift situation. It's an easy thing to play with to see if it helps anyways.
toodeep is offline
post #17 of 19 (permalink) Old 12-21-2010, 11:53 PM Thread Starter
Thanks, Toodeep. If adjusting the idle want fix, I will try to adjust the clutch.
07 Foreman 500
jamnjeep is offline
post #18 of 19 (permalink) Old 12-22-2010, 12:01 AM
Administrator
toodeep's Avatar
Garage
If you need the directions I can post them. They are in the owners manual and all over this forum. Not a bad thing to do every now and then anyways since everything does wear.
toodeep is offline
post #19 of 19 (permalink) Old 07-15-2018, 05:08 PM
Quote:
Originally Posted by toodeep View Post
There is a seat for the throttle needle, it's held in by the main jet. You should be able to look into the carb and see it sticking up slightly.
Is there a correct/incorrect way to put the needle jet back in? When taking the carb apart, I tapped it out with a long dowel and of course. It came all of the way out and I’m not sure which way to re-install it. When looking at the needle jet, one side has a larger inside diameter than the other. Also, when looking at the outside of the needle jet, there is a raised portion that is offset. Does the longer offset go in a certain way? Thanks
goldwing55706 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
'06 TRX350FE carb removal...remove plastics? 911jeep Honda Rancher 350, 400 & 420 5 05-28-2014 10:54 PM
Carb removal and rebuild Suthrn98 Honda Rancher 350, 400 & 420 2 10-10-2013 06:27 PM
2006 Foreman FM project carb removal ?? wheel bearings jeepwm69 Foreman 500 4 02-11-2013 07:40 PM
02 rubi carb removal Hollerdog Rubicon 500 4 11-11-2011 06:11 PM
Carb Removal... Blace Foreman 500 14 01-02-2011 01:07 AM
You may post new threads
You may post replies
