Clunking noise on rear axle - Page 3 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
 7Likes
post #21 of 26 (permalink) Old 04-08-2019, 03:25 PM
mrbb's Avatar
running different sized tires on a 4x4 atv can cause drive line damage, as there not turning at the same amount, and that caused binding in drive line and that can lead to more costly repairs
and quite frankly they should be all of the same type/brand model
as NOT all atv tires measure the same in the same sizes from brand to brand or model to model, so, the name of the game on a 4x4 vehicle is to have matching dia. tires front and back, UNLESS there is different gearing in front diff to back to compensate for the tire size difference!
if on a 2x4 atv, then NO worries!
mrbb is offline
post #22 of 26 (permalink) Old 04-08-2019, 03:28 PM
mrbb's Avatar
also your clunking noise can be from this wrong sized tires on it?
mrbb is offline
post #23 of 26 (permalink) Old 04-08-2019, 04:42 PM Thread Starter
Honda Addict
Quote:
Thanks for the info on the tires, I don't ride it too much as it's been cold but after I get the 1st gear replaced I will go ahead and spring for tires. 26" or 27" should be good, right? I don't know what they come with stock but I don't want to do GR or clutch, not that into it at this time, have many other things that need more attention.
The clunking is definitely the 1st gear now that someone above brought it to my attention. I can hear it when I put it in gear and while engaging it makes the noise.
I want to replace it first before the tires as I will get a very good look at everything when I pull the motor and know whether or not to invest too much more in it or get a different one. I think I wish I would have gotten one a little smaller, (what is it the Rancher with the 420cc on it) this thing is a hog getting between tight spaces and the little extra motor size seems to be countered by all the extra weight.
2007 Foreman 500FM
Wilbur is offline
post #24 of 26 (permalink) Old 04-08-2019, 05:12 PM
mrbb's Avatar
I would stick with 26's than go with 27's and many have less power, taller tires get heavier and rob power and effect handling, and wear and tear on all parts of drive train
plus the alter your stock gearing thus take power away
some folks run lighter 27's and are happy, some ain't all comes down to how much power your willing to loose and live with!
jeepwm69 and Wilbur like this.
mrbb is offline
post #25 of 26 (permalink) Old 04-09-2019, 09:58 AM
jeepwm69's Avatar
Garage
I like light 27's on a Foreman, but 26's you won't notice any power loss at all.
Wilbur likes this.
2009 Foreman 500FM Green
27" Execs on Rubicon rims, Perfex
5K Viper Max winch
Perfex with HL springs
27" Mudbugs on Rubicon rims
Heated Grips and Thumb, HID's
4K Viper Max winch
2006 Foreman 500FM Green
3K Superwinch winch
2009 475 Rancher AT Tan
26" Mudbugs on Rincon rims
jeepwm69 is offline
post #26 of 26 (permalink) Old 04-12-2019, 06:42 PM
Check your back left bearing. I bet its blown all to snot. Mine did the exact same tging you describe, it took me a while to figure it out because if I shook the wheel it had no play. Eventually I pulled the back hubs and found this.
ID:	41445   Click image for larger version
Corey Macdonald is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
Clunking noise. scottyo947 Vintage Honda 8 07-01-2014 07:47 PM
2003 450es Rear Axle Noise SNO_DAY Foreman 450 6 01-04-2013 11:56 AM
oil seals rear axle and axle o-ring hman1055 Honda Recon 0 10-04-2012 09:47 AM
Downshifting clunking 450foreman04 Foreman 450 9 09-16-2010 07:32 AM
Axle nut size on 2004 Rancher AT rear axle? rikerz Honda Rancher 350, 400 & 420 6 08-13-2009 03:27 PM
You may post new threads
You may post replies
