Electric Shift Problem, PLEASE HELP!!!!! - Page 2 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #11 of 20 (permalink) Old 04-24-2012, 12:24 AM
I have a 2008 TRX500FE Foreman with some mods and having problems with the electric shift, 3 blinks (angle sensor) I only have 2100 miles on it, Love the foreman but not the problems. My shifter works fine until I get past half throttle then it starts flashing in whatever gear I am in and I cannot shift unless I stop turn it off and back on and rock it back and forth then I can down shift again, it worked fine untill I got 2000 miles on it then I started having trouble with it. Anyone have any ideas?
2 inch snorkel kit
27 inch BI CLAWS
Warn Winch
Spring covers
Gun rack
Super Trapp Mud Slinger
redneckhondalover is offline
post #12 of 20 (permalink) Old 04-24-2012, 12:42 AM
rich450es's Avatar
Quote:
2 inch snorkel kit
27 inch BI CLAWS
Warn Winch
Spring covers
Gun rack
welcome to the forum !!!
have you adjusted the clutch in awile ?
have you cleaned and put dielectric greese in the conection yet ?
is the battery conections tight and battery fully charged ?
2000 foreman 450 es-s
the f**king pig
SOLD
sold all my crappy Hondas .....lol
sold !2007 Suzuki kingquad 700 for fun
2018 Yamaha grizzly 700 se
friend me on facebook
i love (.)(.)s
rich450es is offline
post #13 of 20 (permalink) Old 04-24-2012, 02:38 PM
I have just now removed the angle sensor, the outside was dirty the connections are not corroded and there are no cracks or anything, Do I grease it where it goes into the motor also or just the plug in? I have not adjusted the clutch yet, I wanted to gut the code says angle sensor so I have started there. I really appreciate the help, Thank you
post #14 of 20 (permalink) Old 04-24-2012, 03:49 PM
rich450es's Avatar
the dielectric greese goes in the connection
and you should have adjusted the cluch first because if the adjustment screw is frozen in the front cover then you could have cleaned the sensor when you pull the front cover
the f**king pig
SOLD
i love (.)(.)s
post #15 of 20 (permalink) Old 04-24-2012, 07:12 PM
Cleaned the angle sensor and re-installed it and it shifts like new, believe me the plastic is the worse part of this job, now since I am feeling pretty confident I am taking apart the left side and pulling the carb so I can see what size the main jet is I am not looking forward to the air cleaner housing with the 2 inch snorkel I have a new HMF basic jetting kit and feel like I will try the 170 main jet depending what is in it, Surely it was rejetted when they put the after market exhaust and custom snorkel but you never can tell so the only way to know for sure is to take the thing apart and look! I have a slight hesitation low in the throttle but top end seems fine, My question is the main jet the only one that needs changed, Idle is a little sluggish to but the main jet control's from half throttle to full throttle so a little confused I may wait for a reply before I pull the carb, it is so nice to be able to down shift again my confidence is restored in Honda's Electric shift program. I am a little hesitant to adjusting my clutch it seems strong, does this need adjusted more on an es model because my father inlaw has a 2000 450s and has never adjusted the clutch. thanks
post #16 of 20 (permalink) Old 04-30-2012, 07:47 AM
I am have to same problem. I changed the angle shift sensor. Could you email me the procedure to clear out the code 5 on the indicator panel. My email address is: [email protected]
englishounds is offline
post #17 of 20 (permalink) Old 04-30-2012, 07:50 AM
Quote:
Originally Posted by Honda Mechanic View Post
No the tests are different .. Post or PM your email address and I will email you the TRX450 section ..
Would you please email to me, having same problem; [email protected]
post #18 of 20 (permalink) Old 06-27-2015, 01:31 AM
How many times do you have to cycle the key to reset on a 450es Honda Foreman 2002 ? Thank you.
Pgordon is offline
post #19 of 20 (permalink) Old 08-20-2019, 01:39 PM
Jeremy Brereton is offline
post #20 of 20 (permalink) Old 09-02-2019, 04:59 PM
I recently purchased a 2002 foreman 450 and have been slowly addressing the problems it has. Almost done, however the electric shift isn't working properly. The guy I bought the bike from installed a 'new electric shift unit the day I purchased it and it's never been right.
When the bike is cold it shifts up okay, however it won't shift down, until you come to a complete stop. I can hear something trying to engage (like a clicking) but it won't downshift. Once the bike has been ridden for a while (10 minutes or so) it seems to shift down okay. What should I look at first? TIA.
Roger Bettoni is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
420 rancher won't shift (electric shift) hunter72206 Honda Rancher 350, 400 & 420 10 02-17-2016 10:39 AM
Electric Shift quit working and so did electric start tjworthen Honda Recon 1 09-17-2012 08:50 PM
Electric shift to Manual shift nsudemon46 Foreman 450 0 01-04-2010 11:54 PM
Electric Shift vs. Foot shift Hondamatic Tire & Wheel Discussion 29 02-19-2008 06:49 PM
electric shift problem gbrinlee Foreman 450 1 09-04-2006 06:13 PM
You may post new threads
You may post replies
