Problems starting and stay running - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
 6Likes
post #1 of 12 (permalink) Old 05-15-2019, 09:45 PM Thread Starter
99 honda 450es. Hard to start when starts acts like it wont take fuel then shuts down. Replaced carb, replaced coil, replaced plug, air filter. Still same ! Any ideas? Please help?
James Roberts is offline
post #2 of 12 (permalink) Old 05-16-2019, 07:24 AM Thread Starter
Ok i have now purchased a CDI possibly the problem ? Just guessing ! Will install tuesday 21 see what happens!
post #3 of 12 (permalink) Old 05-17-2019, 02:22 PM
harig's Avatar
Garage
most aftermarket electronics are hit and miss, be careful trying to save money.....
jeepwm69 and mrbb like this.
harig is offline
post #4 of 12 (permalink) Old 05-17-2019, 08:21 PM
mrbb's Avatar
is the fuel NEW/fresh and good? is inside of tank clean?
is the fuel cap vent working properly?
mrbb is offline
post #5 of 12 (permalink) Old 05-18-2019, 06:17 AM
Honda Lover
Majorpayne's Avatar
There is a fuel strainer inside the tank that could be plugged or need replaced.
Brad
Majorpayne is offline
post #6 of 12 (permalink) Old 06-08-2019, 09:16 AM Thread Starter
Ok i have replaced the cdi and removed tak and cleaned out newfuel strainer in tank clean nothing in tank . put all back and same problem. I choke till finall fires and then will harsly run gradually give gas till it takea it then ride it . but if i shut it off it will not start again. Same thing every day. What now? Like maybe it gets warm or hot and wont restart but when cold it wont harldy start either with out alot of trying.? Puzzled?
post #7 of 12 (permalink) Old 06-08-2019, 10:13 AM
Honda Lover
Right after it dies, is there spark at the plug? (ignition coil or pickup coil breaking down with heat)
When were the valves last adjusted? Any backfiring during restarts or while running?
Possibly the timing chain has jumped?
Moccasin Ranger is offline
post #8 of 12 (permalink) Old 06-08-2019, 11:35 AM
mrbb's Avatar
OK have you done a compression test on this motor<
a worn out top end will have starting issue's and will /can not run when hot
SO< I would start with a compression test and see what that says!
mrbb is offline
post #9 of 12 (permalink) Old 06-11-2019, 08:08 AM Thread Starter
I put air thru strainer and fuel valve nothing plugged. Idk? Fuel hose clea
post #10 of 12 (permalink) Old 06-11-2019, 08:09 AM Thread Starter
Ok i will try compression check thanks guys.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
2006 rancher es350 2x4 wont stay running past idle brian97cobra Honda Rancher 350, 400 & 420 3 03-12-2010 11:12 PM
trx350d needs half choke to stay running? springer130 Foreman 400 2 03-07-2010 02:16 PM
wont stay running joshjohns02 Foreman 450 3 05-14-2009 09:41 PM
won't stay running, even after new plug FatttForeman Foreman 500 3 04-20-2008 10:38 PM
<<<foreman will not stay running>>> hkustoms Foreman 500 6 09-30-2007 11:50 AM
You may post new threads
You may post replies
