oil leak - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 14 (permalink) Old 06-17-2018, 02:21 PM Thread Starter
ChiefSam's Avatar
oil leak
I went out mud ridding yesterday. After a while ridding I saw oil on my left rear wheel and notices of course it was coming from my axle. I checked this and it looks like it has been leaking all might. The oil has to be coming from my rear diff right ? Wanted to know if its a bad deal or what else.
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
Custom oil cooler rack
ChiefSam is offline
post #2 of 14 (permalink) Old 06-17-2018, 03:13 PM
toms99tj's Avatar
I had the same happen on mine before the irs. I never fixes it but when i tore the diff out you can tell the seal on the diff was leaking and the seal on the axle tube was leaking.
1995 Harley Davidson Sportster 1200
___________________
2001 Honda Foreman 450es
___________________
2007 Honda crf250r
Stage 2 Hotcam
toms99tj is offline
post #3 of 14 (permalink) Old 06-17-2018, 04:11 PM Thread Starter
ChiefSam's Avatar
If I look around diff I don't see any oil. Only around the hub but you never know. Is the axle seal the same seal as the one in the front axle because I have some of them or the same seal the rear break drum has from deleteing my break. Just asking so if they are I won't have to order one. Ill change acke seal first to see if that's the only thing.
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
ChiefSam is offline
post #4 of 14 (permalink) Old 06-17-2018, 04:21 PM
toms99tj's Avatar
Doesnt look they are the same seals.
___________________
___________________
2007 Honda crf250r
Stage 2 Hotcam
toms99tj is offline
post #5 of 14 (permalink) Old 06-17-2018, 04:29 PM Thread Starter
ChiefSam's Avatar
I'm stubbern so ill check it out anyway. Not saying I don't belive you. It won't be bad for my axle or diff if I go ridding before I fix the problem ? Just make sure diff has enough oil right ?
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
ChiefSam is offline
post #6 of 14 (permalink) Old 06-17-2018, 04:59 PM
mrbb's Avatar
what yr and model atv are you talking about
I have sen some that had oil blow out of vents and such and leak into axle tube and leak out on ends?
so doesn;'t always mean its a diff leaking gear oil?
but more info on yr and model atv will get you better advice !
mrbb is offline
post #7 of 14 (permalink) Old 06-17-2018, 05:04 PM Thread Starter
ChiefSam's Avatar
98 trx450s
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
ChiefSam is offline
post #8 of 14 (permalink) Old 06-17-2018, 05:08 PM Thread Starter
ChiefSam's Avatar
What vents are you talking about. Air vent line ? I only see leaking out of rear left hub. I deleted my rear break so I can't really tell if its leaking there. Doesnt look like it is
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
ChiefSam is offline
post #9 of 14 (permalink) Old 06-19-2018, 10:39 PM Thread Starter
ChiefSam's Avatar
I just realized today that the day I went ridding last week I changed my rear diff oil. I filled it to the top and today I checked the fill bolt and some oil ran out for like 5 seconds. Before I checked it I saw that it wasn't leaking out my left side axle tube. I just wanna know if it was only leaking because of I over filled and if that tore up my seals.
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
ChiefSam is offline
post #10 of 14 (permalink) Old 06-28-2018, 08:43 AM
Honda Addict
Quote:
Oil was running out the fill hole??? If so, heck yeah you got wayyyy too much oil in there. There's a level plug on the side of the diff........
I'd at a minimum pull the left axle tube and replace the seal and then replace the bearing and outer seal at the hub while it's off.
Rimneck is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
oil leak near oil cooler under front rack c.j. Foreman 500 6 03-03-2011 02:19 PM
Oil Leak cajunforeman Foreman 500 15 03-29-2006 02:31 PM
Rubicon oil leak, Grinding when taking off. Help or For Sale mypaypal Rubicon 500 3 03-01-2006 06:04 AM
Oil leak from sensor in the skid plate !/$%"$%/*$ duckyxpress Foreman 500 5 11-10-2005 03:03 PM
Oil leak, front diff......need help please! netxforeman Foreman 450 1 11-09-2005 08:50 AM
You may post new threads
You may post replies
