oil leak - Page 2 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #11 of 14 (permalink) Old 06-30-2018, 02:57 PM Thread Starter
ChiefSam's Avatar
I have the bearings and seals just haven't installed em yet. I was about to today but I jacked up the rear end and saw that both of my wheels had a little bit to much of a wobble. Both axle nuts where loose. Maybe that's why oil was leaking out of left hub. Ill find out some more and see what else is going on
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
Custom oil cooler rack
ChiefSam is offline
post #12 of 14 (permalink) Old 07-02-2018, 11:06 AM
Honda Addict
Quote:
Axle nuts can be tightened up, but could be an indicator of worn hubs or axle splines.
As for the oil leak, the ONLY reason you'll get oil out of the the left hub area is a failed inner seal at the differential. What usually happens is the LEFT wheel bearing / seal will fail. This lets water / dirt get into the axle tube further deteriorating the wheel bearing. Then your axle will drop down / back a little because the bearing no longer holds it true to the center of the tube. This damages the differential seal and lets your oil out into the tube, and out the wheel bearing seal and slings it all over in inside of your tire.
See diagram below. This is all a very easy fix and as I mentioned earlier, I'd go through the rear axle from hub to hub with new bearings and seals. 3 hours and we'd have this thing better than new (hopfully caught before needing the new axle).
Rimneck is offline
post #13 of 14 (permalink) Old 07-02-2018, 04:45 PM
Honda Addict
Here's what you're looking at if it goes to far.....
Rimneck is offline
post #14 of 14 (permalink) Old 07-05-2018, 07:32 AM Thread Starter
ChiefSam's Avatar
Once I tightened the axle nuts back up It stopped leaking but the left bearing seal was worn out a bit. The axle splines looked good compadre to yhe top one on your picture. I put in new seals and bearing now so hopefully it stays running good next time I go ride. Thanks for the help
1998 TRX 450s
30in Silverbacks
Home made snorkel
K&N air filter
EPI clutch spring
14% GR
Axle paddle
ChiefSam is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
oil leak near oil cooler under front rack c.j. Foreman 500 6 03-03-2011 02:19 PM
Oil Leak cajunforeman Foreman 500 15 03-29-2006 02:31 PM
Rubicon oil leak, Grinding when taking off. Help or For Sale mypaypal Rubicon 500 3 03-01-2006 06:04 AM
Oil leak from sensor in the skid plate !/$%"$%/*$ duckyxpress Foreman 500 5 11-10-2005 03:03 PM
Oil leak, front diff......need help please! netxforeman Foreman 450 1 11-09-2005 08:50 AM
You may post new threads
You may post replies
