#1 (permalink) |
I can go in reverse but when i go foreward, my brakes are seized up. I took the rear brake assembly apart and the drum is still attached to the plate. Howdo i get the drum away from the plate so i can see if that is the problem. HELP???????
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
welcome to the forum. you may have to use a pry bar or even a dead-blow hammer to get it loose. make sure to spray some pb penetrating oil into as well. that will help
2012 TRX500FM FOREMAN. SSPECKERWOOD 3RD HEADLIGHT MOD QUAD BOSS REAR SEAT 26" SWAMPLITES KFI #3000 WINCH HOT GRIPS HEATED GRIPS & THUMB WARMER HONDA ALUMINUM A-ARM GUARDS 00' FOREMAN 450es HIGH LIFTER SPRINGS FRONT & REAR MAXXIS TIRES OFF A 2012 FOREMAN 500 SSPECKERWOOD 3RD HEADLIGHT MOD http://www.flickr.com/photos/sspeckerwood/ http://www.youtube.com/user/sspeckerwood Official hondaforeman.com stickers IF YOU WOULD LIKE OFFICIAL HONDAFOREMAN.COM STICKERS PM ME. |
#3 (permalink) |
it looks like (in the manual)the brake drumm is just splined on the axle but is rusted on . i would hit it with pb blaster and try working it off sorry im not much help but toodeep will come on to help soon
#5 (permalink) | |
Quote:
With both cables off you should be able to move the rear brake arm, pull it towards the back of the ATV, the pads should release (or go back to their rest state) and like ss said, spray PB Blaster or WD-40 around the seam and you should be able to use a pry bar or screw driver to work the plate assembly out of the drum. There is 2 slots on the differential/plate mating surface that you can use to spread the parts. Be careful not to apply to much pressure and mess up the aluminum. Mine were locked up bad, and the axle seal/bearing and the felt dust seal and inner seal on the brake cam were all shot, water and mud had gotten in there and locked it up. Good Luck
"The greatest pleasure in life is doing what people say you cannot do." In a previous life... 1986 ATC 250R 1985 CR500R 1985 ATC 250R 1985 ATC 350X 1983 ATC 200X I liked speed....
#6 (permalink) |
Good point Rich.. I took for granted that the axle nuts were removed...
#8 (permalink) |
do you mean that you cant move the brake shoes ...like the cam is seized trew the brake pannel
#9 (permalink) |
That would be my guess as well, you can seperate the shoes by hand, remove the arm, and tap the cam out... there is 2 seals that I'm guessing are gone.
#10 (permalink) |
Okay i just went and looked and the cam is still attached but the brake arm is not. the actual brake housing is attached to the outer panel and it wont come apart, do i need to take the cam off and then the housing and everything will come off??
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
