#1 (permalink) |
Honda Addict
I have a '04 Recon and I noticed when I pull the front brakes, it seems only the left one is working. I haven't jacked it up and spun the right wheel and applied the brakes yet, but before I rip into it, does anyone have something I should check first ?
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
lift ur front wheels up. test it out to make sure. then check ur adjustments on both sides. the one could just need adjusting
2012 TRX500FM FOREMAN. SSPECKERWOOD 3RD HEADLIGHT MOD QUAD BOSS REAR SEAT 26" SWAMPLITES KFI #3000 WINCH HOT GRIPS HEATED GRIPS & THUMB WARMER HONDA ALUMINUM A-ARM GUARDS 00' FOREMAN 450es HIGH LIFTER SPRINGS FRONT & REAR MAXXIS TIRES OFF A 2012 FOREMAN 500 SSPECKERWOOD 3RD HEADLIGHT MOD http://www.flickr.com/photos/sspeckerwood/ http://www.youtube.com/user/sspeckerwood Official hondaforeman.com stickers IF YOU WOULD LIKE OFFICIAL HONDAFOREMAN.COM STICKERS PM ME. |
#4 (permalink) |
If Helmut says it, its true.
2009 Rubicon Black 350 Miles 2500lbs Warn ITP 212 Machined SS Rims 27" Maxxis Zillas 2" Gorilla Lift Richocett Swing Arm Skid Plate 2" Snorkle HMF Swamp Series UniFilter Rejet Custom Speaker Box Powermadd Black Hand Guards Ammo cans 2007 Rancher ES Red 750 Miles ITP 108 Machined SS Rims Rubicon stock tires Powermadd Black Hand Guards 2 Up Rear Box |
#5 (permalink) |
Honda Addict
If the OP is lucky Helmut will be correct
Water contamination and a leaking wheel cylinder are next on the probability list.
Yeller '02 Rubi with Big A$$ stainless cooler and Cupholder. '06 CRF150F with cooler. '79 F-100 that needs a cupholder
#6 (permalink) | |
Quote:
u'll see it if its leaking. if its not leakin u could have internal damage. keep us informed
#7 (permalink) |
Honda Addict
I've been busy with other projects, but I did jack up the front and spun the tire/wheel and apply the brake. It acted fine and no different than the left side. Right now I'm thinking the bias between the 2 sides is off and the left is grabbing first. Gonna pull both drums and see if there's anything obvious. Thinking it's just a adjustment issue right now.
#8 (permalink) |
Honda Addict
Finally had some time and pulled the drums to check the lining. Both sides looked good, so I put the drums back on. I'm glad I did pull them because the pictures of the adjustments in the manual showed them at different places. On mine they were both at the bottom of the backing plates. I adjusted all 4 till the shoe was dragging the drum, and then backed off 2 clicks. After putting it back together it works better, but the left still wants to grab first. At least it's not pulling anymore and maybe I'll back the left off 1 more click and see what that does.
#9 (permalink) |
What service manual are you using? My '04 Recon factory service manual shows both of the adjusters at the bottom.
2000 Foreman 400 2004 Grizzly 660 Both stock, except for Mudlites and Kimpex rear storage box. |
#10 (permalink) |
Honda Addict
I have the Haynes manual and even they don't have the pictures properly oriented, it shows the adjusters 90* apart.
That's the problem with a manual like mine trying to show many of the models and not identifying the pictures. I need to get one like yours. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
