Recon problem for the expers.. - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 11-13-2010, 03:29 PM   #1 (permalink)
Honda Lover
350rancherboy's Avatar
Default Recon problem for the expers..
I am a long time member on HL. Just signed up here..
I have a recon I picked up awhile back.
It rolls like its in N but display (Its ES) shows that 1st gear is flashing 3 times (angle sensor) AND It shows a solid light for 4th gear (not flashing).
And on top of that it doesnt run. ATV looks pretty clean (PUll ropes not full of mud or anything..motor is stained realy bad) I cleaned carb and put fresh gas in it and its not running still, gets spark but doesnt seem normal? Only sparks every so often...Seems like it doesnt spark enough..
Heres my Link to my HL post, some pics there
And I took my shifter motor off the front, while I was there i noticed my angle sensor was broken, right in 2 pieces! Check out the pictures on HL, HOpefully someone on here can help me out!
Honda Recon, shifting ?
thanks!
ATVLESS
350rancherboy is offline   Reply With Quote
Old 11-13-2010, 04:15 PM   #2 (permalink)
Administrator
toodeep's Avatar
Default
Welcome to HF. The angle sensor defiantly needs to be replaced. Does it shift manually into gear using the tool? Hows the battery and fuses?
Old 11-13-2010, 06:17 PM   #3 (permalink)
2003 foreman es's Avatar
Default
to the forum...
03 Foreman ES
Too much to list...
2003 foreman es is offline   Reply With Quote
Old 11-13-2010, 07:13 PM   #4 (permalink)
Honda Lover
Default
Good batt. and good fuses
IT DOESNT SHIFT AT ALL WITH BACKUP SHIFTER! (dont take that like screaming tone) lol
The backup shifter is locked up..maybe shift fork/drum idk....angle sensor is broken in half, it needs to be replaced
But i wanna know why its locked up, why it shows 1st and 4th and doesnt run
ATVLESS
Old 11-13-2010, 08:03 PM   #5 (permalink)
Administrator
toodeep's Avatar
Default
I'm going to guess the shifting problem will be found under the front engine cover. It could be anything from the reduction gears for the ES control motor to the bolt on the shift drum. It's also possible that it's at the rear of the motor but I would start with the front side since that has almost all the shifting components.
An idea of the parts in there. #13, 12, 18 or 38 would be my guess for a damaged part.
Heartland Honda | Honda OEM Parts | Honda Engines OEM Parts | Honda Power Equipment OEM Parts
Once you get it shifting the other problems might work themselves out.
Old 11-13-2010, 09:36 PM   #6 (permalink)
Honda Lover
Default
Ok toodeep...I clicked the link but it was to a parts fiche, Im guessin this is the pg. you wanted me to see, will you help me on this? Id greatly aprreciate it!
Right now Ive got the shift motor from the front of the motor off. (It still wont shift with the backup shifter) I need to pull the front cover (clutch cover?) And look for the broken pieces you mentioned..
Thank you!!!!! I really aprreciate it!
ps, the link is the pic you want me to be looking at?
ATVLESS
Old 11-14-2010, 12:07 AM   #7 (permalink)
Administrator
toodeep's Avatar
Default
They updated obviously and it won't link the page, look under gear shift drum for the picture. Yes, I think the problem will be found under the clutch cover unless a tooth broke off of the reduction gear (shift control motor) and is jambed, that is not likely but possible.
Old 11-14-2010, 10:14 AM   #8 (permalink)
Honda Lover
Default
I took the shift motor off, but Didnt really know what I was looking at, Ive pressure washed the atv and stood it on its back, I will be pulling the clutch cover today and poke around and snap some new pictures for you toodeep.
I really appreciate any help you can throw my way
thanks
ATVLESS
Old 11-14-2010, 10:15 AM   #9 (permalink)
Honda Lover
Default
ATVLESS
Old 11-14-2010, 10:16 AM   #10 (permalink)
Honda Lover
Default
ATVLESS
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
