04 Recon ES Idle Problems - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 08-28-2010, 11:32 AM   #1 (permalink)
Default 04 Recon ES Idle Problems
When I start up my Recon it fires right up.. But if I dont keep giving it a little throttle it will die..
Also, if im riding and then wanna stop. My Recon will die if i dont do the same. So, Practically if i dont keep the throttle going my quad will die.
Any ideas?
04Recon is offline   Reply With Quote
Old 08-28-2010, 11:42 AM   #2 (permalink)
Administrator
toodeep's Avatar
Default
Might just need the idle set up some or the choke could be stuck in the pulled position.
Old 08-28-2010, 01:54 PM   #3 (permalink)
Default
I've messed with the idle screw up and down and it still doesnt make a difference. And the choke is fine. Ive already made sure it was okay.
Old 08-29-2010, 03:18 PM   #4 (permalink)
Honda Addict
Default
Are you sure it was the idle screw you were turning ?
Black Diamond Motorsports XPS Pontiac GXP
Mind Science Motorsports
American Drag Racing League
Andamo is offline   Reply With Quote
Old 08-29-2010, 09:56 PM   #5 (permalink)
Default
Yes im pretty positive. I looked at the Honda manual that came with the quad to locate the right screw.
Old 08-29-2010, 09:59 PM   #6 (permalink)
2003 foreman es's Avatar
Default
to the forum.
How old is the fuel? Perhaps the carb needs a good cleaning.
03 Foreman ES
Too much to list...
2003 foreman es is offline   Reply With Quote
Old 08-30-2010, 12:00 AM   #7 (permalink)
Default
Well, I just bought it off a friend whose had it in the garage for a long time. When I bought it, had about a half tank. I filled it up with new fuel on top of the old, probably a dumb move on my part but it runs great and all, but when you let off the throttle it goes down. The carb was my next guess also.
Old 08-30-2010, 12:46 AM   #8 (permalink)
Helmut's Avatar
Default
Yeah, sounds like the carb needs cleaning.
Helmut is offline   Reply With Quote
Old 08-30-2010, 08:42 AM   #9 (permalink)
Gauntlet3D's Avatar
Default
Yeah, I would make sure the air filter is OK and drain the fuel and clean the carb. Or maybe just some marine formula Stabil to try and get the water out that way, if there isn't too much. Good luck.
2009 Rubicon Black 350 Miles
2500lbs Warn
ITP 212 Machined SS Rims
27" Maxxis Zillas
2" Gorilla Lift
Richocett Swing Arm Skid Plate
2" Snorkle
HMF Swamp Series
UniFilter
Rejet
Custom Speaker Box
Powermadd Black Hand Guards
Ammo cans
2007 Rancher ES Red 750 Miles
ITP 108 Machined SS Rims
Rubicon stock tires
2 Up Rear Box
Gauntlet3D is offline   Reply With Quote
Old 08-30-2010, 11:05 AM   #10 (permalink)
Default
The air filter is in perfect shape, clean as can be. Time to clean the carb I suppose.
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
