smoking need help - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 08-27-2010, 09:01 PM   #1 (permalink)
Default smoking need help
i got a 2002 honda recon its smoking and spiting oil out of the crank case hose to the air box. ANY CLUE
reconhoss is offline   Reply With Quote
Old 08-28-2010, 01:06 AM   #2 (permalink)
Administrator
toodeep's Avatar
Default
Over full on oil or the rings are shot.
Old 08-28-2010, 09:10 AM   #3 (permalink)
Honda Addict
Default
Did it start smoking all of a sudden or has it been smoking all along ? It sounds like you have compression blowing past the rings. You need to do a leak down of the cylinder and I'll bet you'll be able to hear the air blowing into the crankcase.
As the previous poster said, check the oil level first, but I think the problem is more serious than that.
Black Diamond Motorsports XPS Pontiac GXP
Mind Science Motorsports
American Drag Racing League
Andamo is offline   Reply With Quote
Old 08-28-2010, 10:10 AM   #4 (permalink)
Honda Lover
FloatingForeman's Avatar
Default
Quote:
to the fourms. sounds to me like your overfull on oil
FloatingForeman is offline   Reply With Quote
Old 08-28-2010, 01:31 PM   #5 (permalink)
Default
its been smoking all along it has no power at all it will drive but it bogs down when i turn i checked the oil and its normal
Old 08-28-2010, 01:58 PM   #6 (permalink)
Honda Lover
Default
Well sounds like an compression problem could be a couple of things worn rings, scratched cylinder wall, bad valve seals. Toodeep or someone else can prob give you a better idea but in the end you will have to tear it apart to know for sure
Old 08-28-2010, 02:21 PM   #7 (permalink)
Default
if the rings were bad wouldnt it smoke out of the exhaust
Old 08-28-2010, 04:33 PM   #8 (permalink)
Honda Lover
Default
ohhh i didn't see that it was smoking out of the crankcase breather hose dont know about that not i gusse well have to wait and see what others have to say
Old 08-29-2010, 03:16 PM   #9 (permalink)
Honda Addict
Default
As the piston goes up a down the bore, oil is slung onto the walls. As the spark plug fires at the top of the compression stroke the mixture of gasoline and air is getting past the rings and into the crankcase. All this volume of gasoline/air/oil mixture is vented out the crankcase into the air box. Since you say it has now power, you're losing all your compression because of bad rings, cracked rings, broken ring lands, cracked piston, etc. Something has happened along the way for this to happen because these motors are practically bulletproof. Doing a compression test will guide you as to what is wrong. Continued driving can cause futher damage to the walls.
Old 08-29-2010, 04:30 PM   #10 (permalink)
Default
ok thanks for the help
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
