smoking need help - Page 2 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-30-2011, 12:09 AM   #11 (permalink)
Default
if you want to do a leak down test this is how to do - this is from a honda technical advisor i used to deal with-- pull the spark plug and if you can find a compression tester with a quick coupler for an air hose from a compressor, hook it up and look/listen for leaks oil sputtering out. generally compression for a honda engine should be around 120 psi so if your compressor is set at that it should work.
bobs330 is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
