Honda recon problems - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 4 (permalink) Old 03-21-2010, 09:20 PM Thread Starter
I have an 2001 honda recon, it has been sitting for a few years.. replaced the air filter, spark plug and drained the gas and also cleaned the carb out.. the 4 wheeler will only run on the choke... any suggestions???
honda recon 250 is offline
post #2 of 4 (permalink) Old 03-27-2010, 10:16 AM
even after it's warmed up?
Maniac1976 is offline
post #3 of 4 (permalink) Old 03-27-2010, 04:55 PM
When you say you cleaned out the carb, can you describe that process exactly? I'm thinking that after setting up for several years, it may need more than just a few shots of carb cleaner down the pipes - you may need to really pull that carb apart and give it a good cleaning from the inside out.
jode is offline
post #4 of 4 (permalink) Old 03-31-2010, 11:29 AM
It could be that you are running too lean when the choke is open. Meaning that when you pull the knob out for the choke you are actually closing the choke plate creating a richer mixture for start up. As the engine warms and the choke opens it creates a leaner mixture as more air is allowed in. So when you state that it will only run on the choke, it sounds like the engine needs that richer fuel mixture. Have you adjusted the mixture screw? I do not know a lot about the carbs on these atv's, but I think a carb is a carb no matter the application.
bigfoot is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
