Clean Fuel tank - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-22-2010, 02:42 PM   #1 (permalink)
Default
My atv sat for about 4 years without running (its a 2001 recon). the fuel tank was never emptied. The fuel turned orange. Anyways I am working on my atv and trying to get it running. The bottom of the fuel tank has some crap on it and was wondering if anyone can suggest a way to clean it. I dont want that stuff to get into the engine.
thanks
mb02020 is offline   Reply With Quote
Old 01-22-2010, 03:09 PM   #2 (permalink)
Administrator
toodeep's Avatar
Default
Just flush it, put some fuel in it and shake it around and dump. Add an in line fuel filter to the gas line to be safe.
Old 01-22-2010, 10:06 PM   #3 (permalink)
2003 foreman es's Avatar
Default
Filter is a great idea. May be spray carb cleanerin the tank also may help?
03 Foreman ES
Too much to list...
2003 foreman es is offline   Reply With Quote
Old 01-23-2010, 10:14 PM   #4 (permalink)
Honda Addict
Default
See if you can get some Stoddard Solvent at maybe Lowe's, Home Depot or a paint supply store. Put some of that into the tank and keep sloshing it around. Let it set overnight and then drain or dump it out. Stoddard is a mild solvent and won't hurt the tank since it's a Naphtha cut off a distillation column. It might take 2 or 3 attempts, but it should do the job for you.
And if that orange crap is in the bottom of the tank, you can safely assume it's all the way into the carb.
Andamo is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
