Replacing rear brakes on Recon - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 07-31-2009, 03:07 PM   #1 (permalink)
Default
Looking to replace rear brake shoes on a 2003 Recon and the service manual calls for two 41mm wrenches to remove the axle nuts. All I could find is a 1 5/8" which would likely work but is $78!!! What does everyone else do, use a pipewrench, take it to the dealer?
blakey is offline   Reply With Quote
Old 07-31-2009, 03:46 PM   #2 (permalink)
Administrator
toodeep's Avatar
Default
Big crescent wrench or pipe wrench will work.
Old 07-31-2009, 04:11 PM   #3 (permalink)
Default
Thanks, I will give it a try.
Old 07-31-2009, 04:17 PM   #4 (permalink)
budmc77's Avatar
Send a message via AIM to budmc77 Send a message via Yahoo to budmc77
Default
QUOTE (blakey @ Jul 31 2009, 03:07 PM)
$78!!! Where are you shopping?
'02 Honda Rubicon 500
-Warn 2000lb Winch
-Warn 424 Select
-Warn Pushbar
-Perplex 2" Lift
-25" ITP MudLite Tires
-Highlifter Front Disc Brake Converstion Kit
-Hand Warmers
If it's worth doing the first time, it's worth doing right
budmc77 is offline   Reply With Quote
Old 07-31-2009, 06:34 PM   #5 (permalink)
Default
QUOTE (budmc77 @ Jul 31 2009, 09:17 PM)
Canada...
Old 08-01-2009, 08:58 AM   #6 (permalink)
Default
Got the brakes apart and shoes replaced last night, they were full of slimy mud from the previous owner. What a stinking mess! Ended up using a couple older pipewreches that had well worn jaws so they hardly left a mark.
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
