Honda Recon won't stay running - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 12 (permalink) Old 08-08-2016, 05:18 PM Thread Starter
Exclamation Honda Recon won't stay running
I have an old 2000 Honda Recon, and it doesn't seem to want to stay running. The engine turns over and will run if I hit the throttle, but eventually it backfires and dies. I cleaned out the gas tank and freed up the petcock, and there is gas flowing. What should I try next?
connorwerts98 is offline
post #2 of 12 (permalink) Old 08-08-2016, 08:19 PM
Honda Lover
Will it stay running indefinitely if you keep feathering the throttle but dies if you let off the throttle? I am assuming this is a cold engine condition...Are you using the choke?
Darrell
DT400 is offline
post #3 of 12 (permalink) Old 08-08-2016, 08:27 PM
mrbb's Avatar
try a new spark plug?
is air filter clean?
clean the carb>
star there and see what happens
mrbb is offline
post #4 of 12 (permalink) Old 08-16-2016, 05:14 PM Thread Starter
Quote:
Darrell
clean the carb>
I replaced the spark plug, and the old one was burnt out and black. Once I replaced it, it started easily and ran for a little while but it was blowing a ton of blue smoke out. After riding for a minute to test things, it died. It now takes a long time to start and doesn't idle at all again. The carb has been cleaned and there is gas flowing from what I can see. Any suggestions?
post #5 of 12 (permalink) Old 08-16-2016, 06:22 PM
Honda Lover
Quote:
Answer my first questions.
Either running rich and/or weal spark.
Didi it have good power when it was running with the new plug?
Darrell
DT400 is offline
post #6 of 12 (permalink) Old 08-16-2016, 06:27 PM
mrbb's Avatar
ok, if its burning oil, lots of smoke, you could have a bad top end, and low compression , which will cause it to NOT idle well
I'd do a compression test here to see where your at
fast easy simple to do! and lets you know for sure where the motor is at on that
as all the fuel, carb adjustments you make will NOT solve low compression!
mrbb is offline
post #7 of 12 (permalink) Old 08-16-2016, 06:39 PM
Honda Lover
Was the plug fouled wet and oily or dry fluffy black?
It's either running rich/weak spark or something went south in the cylinder.
If the smoke was blue that is oil...rich condition is black/grey
Darrell
DT400 is offline
post #8 of 12 (permalink) Old 08-22-2016, 10:21 PM Thread Starter
Darrell
The plug was dry and black. I've been working on doing minor things for the past few days and I still seem to have the same problem as I mentioned in my last post.
post #9 of 12 (permalink) Old 08-22-2016, 10:41 PM Thread Starter
It actually did idle well after the new plug was put in, but it died after five minutes and now doesn't idle at all again. I don't own a compression tester, so I'll look into buying one to test the compression soon.
post #10 of 12 (permalink) Old 08-23-2016, 09:11 AM
Honda Lover
Still need to answer the question will it run if you feather the throttle and NOT let it idle?
Dry fluffy black soot is rich.
Do you have a red/orange or a blue/purple spark?
Did you do anything to the carb before the issue arose?
If the spark is OK then it's fuel.
It might be something as simple as the the float/needle being stuck or debris between the needle and seat.
I would go ahead and pull the carb and check those items out.
You might just be able to pull the bowl and then take the float off and clean the needle and seat.
Darrell
DT400 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
