transmission problems? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 9 (permalink) Old 07-12-2012, 04:35 AM Thread Starter
i have a 2001 500 rubicon. when i put it in drive it displays d1,d2 and esp all at the same time on the screen and makes a grinding noise like 2 gears slipping but goes away if given gas but stuck in like 1st gear cant shift gears manualy. when put in low it works fine. does this sound like transmission problems or bad sensor
thanks for any help
200es is offline
post #2 of 9 (permalink) Old 07-12-2012, 09:25 AM
rich450es's Avatar
welcome to the forum !!
it sounds like the transmition has gone bad.
theres alot of threds about that grinding noice being the trans thats junk
2000 foreman 450 es-s
the f**king pig
SOLD
yellow 2003Rubicon all stock and gona stay that way !!!!
red 2000 foreman 450es
1990 Honda 300 4x4 blue stock with plow
friend me on facebook
i love (.)(.)s
rich450es is offline
post #3 of 9 (permalink) Old 07-12-2012, 09:57 AM
j00fek's Avatar
your oil level correct after letting it idle for 10m?
01 TRX500FA
7000+ Mi
850+ HRS
.20 ovr w/ Numara 92.46
carb mod
Warn 424
perfex long travel kit
26in BearClaws
Warn U2500 w Syn Rope
K&N Air Covered by OuterWare
Wes Industries Rear Seat
j00fek is offline
post #4 of 9 (permalink) Old 07-16-2012, 01:50 AM
martdog420's Avatar
check your oil pressure before you do anything.. might only be bad oil pump or chain jumped. DO NOT run it till you check the pressure because if its oil pressure you wont be getting any oil to the top of your motor..
2006 Rubicon Canadian Trail Edition.
1 1/2 inch Quadrax lift
26" Mudlites
Motovan B series back seat
2500# warn
1000's of custom scratches
100's of dings n dents
50+ plastic stitches
and a few oil changes.
martdog420 is offline
post #5 of 9 (permalink) Old 07-16-2012, 02:23 AM Thread Starter
how would i check the oil pressure?
200es is offline
post #6 of 9 (permalink) Old 07-17-2012, 06:38 PM
martdog420's Avatar
there is a small allen plug on the left side of the motor, remove it and hook up a oil pressure gauge. do a search in the rubicon section to find the correct pressure or check your manual because i dont remember the correct pressure but it is quite high.
26" Mudlites
2500# warn
post #7 of 9 (permalink) Old 07-17-2012, 07:55 PM
j00fek's Avatar
01 TRX500FA
7000+ Mi
850+ HRS
carb mod
Warn 424
26in BearClaws
j00fek is offline
post #8 of 9 (permalink) Old 07-17-2012, 08:09 PM
j00fek's Avatar
01-04 rubi manual: 2001-2003 Rubicon 500 Service Manual.pdf
01 TRX500FA
7000+ Mi
850+ HRS
carb mod
Warn 424
26in BearClaws
j00fek is offline
post #9 of 9 (permalink) Old 01-27-2017, 12:03 PM
I have the same problem but the transmission don't make noise it will go just won't shift but put it in low and can shift manly
LeviJackie Weatherford is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
