Throttle Body Sensor Code - Page 3 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-23-2012, 07:39 PM   #21 (permalink)
Administrator
toodeep's Avatar
Default
For the 4x4 the first thing I would do is jack up the front of the machine and hold one wheel while someone rotates the other wheel. Make sure there is some resistance there and a CV joint didn't break or something. Then I would put the machine in 4x4 (key switch on to activate it) and make sure you hear the actuator engage at the front differential and turn the tires to see if any of the drive line is turning. You want to rule out any mechanical problems before chasing electrical. This is something both of the shops should have checked but you never know.
Old 01-24-2012, 07:41 PM   #22 (permalink)
Default
toodeep....thanks for your help! Jacked up the front of the bike, tire check is good. The only sound I hear is a faint click of the Actuator not a actual engaging sound. And the drive is turning.
HondaGirl is offline   Reply With Quote
Old 01-24-2012, 07:58 PM   #23 (permalink)
MudCritter's Avatar
Default
While your checking things might check the fuses. Had mine fill up with water once caused several weird problems.. Good Luck
2008 White Foreman 500 FPM
Clutch Kit ,Jetted, K&N Filter & Outerwears
HMF Exhaust
HMF Exhaust Snorkel
2" Full Custom Snorkel
29.5 " S/W Outlaws on ITP's
2 " Lift
450 Rear Swingarm
Extreme 15.5% GR
Warn 3000# Winch
2004 Green 450 ES___________.2005 Sportrax 250
Standard Bore Weiseco Piston__.Weiseco Piston
27" S/W Outlaws on STI's____.Milled & Ported Head
Viper 2500 lb Winch._______ .22x12.5 Swampfox's
Everthing Else Stock [ For Now ]
MudCritter is offline   Reply With Quote
Old 01-24-2012, 08:02 PM   #24 (permalink)
MudCritter's Avatar
Default
The fuses looked good but the fuse box was holding water in the bottom , couldnt see it but I blew it out with an air blower things started working right .
HMF Exhaust
HMF Exhaust Snorkel
2 " Lift
450 Rear Swingarm
Extreme 15.5% GR
Warn 3000# Winch
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
