03 Rubi 500 Shifting problems - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-15-2012, 08:52 AM   #1 (permalink)
Default 03 Rubi 500 Shifting problems
Hi guys I'm new to the sight here and after looking through the forums I couldn't find anyone with the same problem as me but they all sort of got the same answers back and I will try try them like clean all connectors and stuff.
When I put my bike in reverse and back up everything is ok but once I put it in drive I get error lights flashing on the dash at a consistent flashing and won't come out of first gear. It's doesn't flash 5 times, stop and repeat to get a code. I can shut off the bike and start it again and it will be fine but just don't trust it to go on a long trip. My battery is fine and checked the connections around it. Any ideas? Anything will help
ipetrie_99 is offline   Reply With Quote
Old 01-15-2012, 10:08 AM   #2 (permalink)
rich450es's Avatar
Default
welcome to the forum !
im not realy good on the rubicons but someone will chime in to give you a hand !
if you need a manual just PM me........rich
2000 foreman 450 es-s
the f**king pig
2500lb warn winch
foreman 450 parts for sale
pm me for info
Old 01-15-2012, 12:33 PM   #3 (permalink)
Eagle_On's Avatar
Default
make sure your switch for D1, D2, and esp is not in the middle of two
04 rubicon
-28 zillas
Eagle_On is offline   Reply With Quote
Old 01-16-2012, 02:57 AM   #4 (permalink)
Default
I'm pretty sure I tried switching the D1 D2 and esp and it still wouldn't come out of first gear. I'm working offshore right now for a few more weeks so i can't try anything just yet but thanks for the replies.
Old 01-16-2012, 03:20 AM   #5 (permalink)
Eagle_On's Avatar
Default
when mine did this. my battery was dead and had a bad connection
04 rubicon
-28 zillas
Old 01-16-2012, 03:21 AM   #6 (permalink)
Eagle_On's Avatar
Default
test the angle sensor. do you need a manual?
04 rubicon
-28 zillas
Old 01-16-2012, 10:49 AM   #7 (permalink)
Administrator
toodeep's Avatar
Default
Your getting problem code 5 (5 flashes)? If so that is the angle sensor system and a good place to start testing stuff.
Welcome to the forum.
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
