Heated grips,thumb warmer,what power wire? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-13-2012, 09:40 PM   #1 (permalink)
Default Heated grips,thumb warmer,what power wire?
Hello everyone,i just recieved my moose hand and thumb warmers,they where seperate items with the plastic rocker switches.
My question is which wire are you guys using for power?,i would like it so that they are only powered while the bike is running,not hot at all time, or hot when keyed on,just hot when running?is this possible?, thanks for your time.
MachU is offline   Reply With Quote
Old 01-13-2012, 09:45 PM   #2 (permalink)
rich450es's Avatar
Default
the pink wire off the keyed ignition switch . or the power wire off the 12 volt excesory switch
2000 foreman 450 es-s
the f**king pig
2500lb warn winch
foreman 450 parts for sale
pm me for info
Old 01-13-2012, 09:48 PM   #3 (permalink)
Default
Thank you sir,thats saves me a little bit of brain damage...i hate wiring ...LOL
Old 01-13-2012, 09:51 PM   #4 (permalink)
rubiranch's Avatar
Location: Big Rock Candy Mountain Resort - Marysvale, Utah
Default
I attached the wires directly to the battery.
I hate cutting into wires unless I have and when I do I always solder and heat shrink the connections.
2012 Polaris 550 Touring EPS
Thank you Doug Meyer ATVTV.com
& Polaris 1000+ miles
2001 Rubicon Bug
16,000+ miles 1835+ hours
Dependability is the "Way Out"
Not "True-4-WD".
Bombardier BR 180 Snow Cat
Thanks Utah State Parks
rubiranch is offline   Reply With Quote
Old 01-13-2012, 09:51 PM   #5 (permalink)
rich450es's Avatar
Default
anytime !
the f**king pig
2500lb warn winch
pm me for info
Old 01-13-2012, 11:03 PM   #6 (permalink)
Super Moderator
h22ate's Avatar
Default
Rich nailed it, its not hard to do. I did it when I got my moose grips and thumb warmer 3 years ago and they're still working great!
08 Rubicon
‚——P--;===ฑ--= <-
!‚–’ฏƒนถ
http://youtu.be/U71bn4ZF4K0
h22ate is offline   Reply With Quote
Old 01-18-2012, 08:04 PM   #7 (permalink)
Default
Did you guys cut the hand warmers and use the stock bar ends?
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
