#1 (permalink) |
I have a 2003 rubicon 500 and my reverse would start to sputter. I would shut off my atv and start it back up again and thta would only work for a little bit.
I did the initilizing and i could hear the control motor spin both ways. I read that it could be the angle sensor so i took it off to see if it was durty and put it back together... no when i initilize it the control motor just clicks and that's it. no cycle at all. Also it flashes d1 d2 esp all the time now and runs like crap. What the **** did i do to it? My code flashes a Code #6. How do i free up that control motor? Any help would be great. Thanks |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
I read a post about turning the angle sensor toward the motor and rotate clockwize and put in the screws.
Now the sensor will move forward and reverse but i'm still getting the flashing lights and runs like crap. i ordered a new angle sensor and i'll start from there. Any more thoughts?? |
#3 (permalink) |
well. today i went out and checked my grounds, unpluged and pluged some connections and went for a test drive. Everything was woring great....i'll see how long this last. Still waiting for the new angle sensor,,
These things are touchy... |
#4 (permalink) |
Honda Lover
Sounds like a control motor lock, probably had something to do with the angle sensor..... I've replaced mine about 3 times already... I'm having the same problem where you only get the click with the control motor during the initialization process I BELIEVE this is fixed by removing the control motor and spinning the gear inside .. someone with way more experience than me will chime in i'm sure to correct me.. but **** try it its only 2-3 bolts 10mm to remove the control motor.. and a small flat head to get it moving
06 Rubi 26" Mudlite XLs (soon to be 28" Silverbacks, if I keep this thing) Snorkel HL 2" Lift 05 400AT spawn child of satan - Sold That SOB |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
