Rear diff vent oil loss - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-04-2012, 11:19 PM   #1 (permalink)
Default Rear diff vent oil loss
Question for you mechanics, am getting alot of oil coming out of the rear diff vent line. The one closest to the brake drum. The oil vents to the front and drips down onto the front diff. What would cause to vent alot of oil??
farmer001 is offline   Reply With Quote
Old 01-04-2012, 11:40 PM   #2 (permalink)
sspeckerwood's Avatar
Default
its because you have a bad seal on you rear axle. drain your rear brake housing to see if oil comes out
2012 TRX500FM FOREMAN.
SSPECKERWOOD 3RD HEADLIGHT MOD
QUAD BOSS REAR SEAT
26" SWAMPLITES
KFI #3000 WINCH
HOT GRIPS HEATED GRIPS & THUMB WARMER
HONDA ALUMINUM A-ARM GUARDS
00' FOREMAN 450es
HIGH LIFTER SPRINGS FRONT & REAR
MAXXIS TIRES OFF A 2012 FOREMAN 500
http://www.flickr.com/photos/sspeckerwood/
http://www.youtube.com/user/sspeckerwood
Official hondaforeman.com stickers
IF YOU WOULD LIKE OFFICIAL HONDAFOREMAN.COM STICKERS PM ME.
sspeckerwood is offline   Reply With Quote
Old 01-04-2012, 11:40 PM   #3 (permalink)
Eagle_On's Avatar
Default
too much oil??
04 rubicon
-28 zillas
Eagle_On is offline   Reply With Quote
Old 01-04-2012, 11:42 PM   #4 (permalink)
Default
Quote:
Originally Posted by Eagle_On View Post
too much oil??
dude, just hang back and dont reply just yet. he specifically asked for mechanics.........
QUAD BOSS REAR SEAT
26" SWAMPLITES
KFI #3000 WINCH
00' FOREMAN 450es
Old 01-05-2012, 12:19 AM   #5 (permalink)
Administrator
toodeep's Avatar
Default
Ya but young C is correct, if the final drive is overfilled it could force it out the seal and into the brakes. It should force it out of the final drive vent line but that could be plugged.
toodeep is online now   Reply With Quote
Old 01-05-2012, 12:22 AM   #6 (permalink)
Eagle_On's Avatar
Default
haha its common sense sswood
04 rubicon
-28 zillas
Old 01-05-2012, 08:43 PM   #7 (permalink)
Default
Thank you for the replies. Would have to see a schematic, but overfilled- "no way" there is no oil leaking from the brake drum assembly. Will pull rear wheel and brake assembly to see if there is oil. Now I can assume there is 2 seals on the left side, 1 located on the diff and 1 located before the brake housing? Will check also if the diff vent line is plugged.
Old 01-05-2012, 08:46 PM   #8 (permalink)
Default
pm rich450es for a manual. that will aide you in the pulling apart of your machine
too much oil??
hmmmm......
Quote:
read it and weep....
common sense tells me that a user that posts 3 word answers to anyones question has alot that, what is it, oh ya, common sense.......
QUAD BOSS REAR SEAT
26" SWAMPLITES
KFI #3000 WINCH
00' FOREMAN 450es
Old 01-05-2012, 09:13 PM   #9 (permalink)
Eagle_On's Avatar
Default
ummm whatt?
04 rubicon
-28 zillas
Old 01-05-2012, 09:18 PM   #10 (permalink)
rich450es's Avatar
Default
ummm whatt?
thats only 2 words c-train
2000 foreman 450 es-s
the f**king pig
2500lb warn winch
foreman 450 parts for sale
pm me for info
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
