oil filter and drain plug locations - Page 2 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #11 of 18 (permalink) Old 01-17-2011, 01:06 PM
The filter is behind a 3" round cover on the bottom of the bike in between the two drain plugs.
Pibster
2006 Rubicon
Pibster is offline
post #12 of 18 (permalink) Old 01-17-2011, 01:52 PM Thread Starter
Is that where that large drain plug was. It was between the 2 main drain plugs
warrington is offline
post #13 of 18 (permalink) Old 01-17-2011, 02:46 PM
Administrator
toodeep's Avatar
Garage
I'm thinking yes. Stick the plug (long hollow bolt) back in about half way and wiggle it back and forth. The oil filter cover should come loose then. There will be a spring and washer in there also.
1987 350D (work in progress)
toodeep is offline
post #14 of 18 (permalink) Old 01-17-2011, 04:07 PM Thread Starter
I will try that tonight, thanks for your help. the whole cover will come off i am guessing. Is there 3 other screws as well that have to come out or just the main bolt?
post #15 of 18 (permalink) Old 01-17-2011, 04:08 PM
rubiranch's Avatar
I always replace both aluminum drain plug gaskes as well as both o-rings on the filter cover and center bolt.
It should hold just over 5 qts of oil.
2014 Kawasaki Brute Force 750i EPS
currently 3008 miles & 262.4 hrs
average speed - 11.46 mph
RIP
2001 Rubicon Bug
rubiranch is offline
post #16 of 18 (permalink) Old 01-17-2011, 04:11 PM Thread Starter
perfect, what type of oil are you running. Where is the best place to purchase the gaskets and o rings
post #17 of 18 (permalink) Old 01-17-2011, 04:16 PM
rubiranch's Avatar
Quote:
I'm the odd ball, I buy Honda oil filters, the aluminum drain plug gaskets and o-rings from my local Honda dealer. I know you can buy them cheaper from other places but you can't buy better.
I like Valvoline 10w40 ATV oil and have been using it for the last 11,000 miles.
I'm sure there are "better" and/or "cheaper" but I'm happy with what I use and I'm the only one who counts.
I figure I have spent about $800 for oil changes over the last 10 years. Money well spent in my opinion.
RIP
2001 Rubicon Bug
post #18 of 18 (permalink) Old 01-17-2011, 06:03 PM
Honda Addict
Oil filter is not exposed like a car, it is a cartridge. Location is bottom center under front skid plate. I believe 13mm head on bolt. Looks like a round cover with cartridge inside. be careful to not loose washer, spring or any o-rings. Cover may not come off easily and may need small scraper or razor blade between cover and housing to get it loose.
joelukex4 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
