06 Knocking noise and burning oil - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 09-08-2010, 10:38 PM   #1 (permalink)
Default 06 Knocking noise and burning oil
I have an 06 Rubicon and there is a knocking noise. My guess would be the main crank bearings so I tried to look them up and it looks like you can't buy just bearings, you have to buy the whole crankshaft and rod assembely... WOW $400!!!
Is there any way around this?
Also Its a loud knocking noise and it sounds like it is coming from the bottom. I haven't adjusted the valves yet so I need to try that but am pretty sure that the noise is not the valves. The valves are more of a ticking noise.
Another problem with it is it smokes pretty good. If I rev it up to about 3/4 throttle it will not burn anymore and run clean. Then if I rev it down to about half throttle it will sputter like its miss firing and start burning oil again. Then when I rev it up more it will clear out. Could it all just maybe valves? It has 1xx hrs on it so not that many...
Any help would be great.
Thanks
jeepeater2003 is offline   Reply With Quote
Old 09-08-2010, 10:53 PM   #2 (permalink)
Honda Lover
FloatingForeman's Avatar
Default
i haven't heard of many crank bearings going out i would say check the timing chain/tensioner the valves would make alittle noise but not a whole lot as far as the smoking goes bad rings/ scared cylinder
-Honda Rancher 350-
-Wiseco Piston-
-Kenda Executioners-
-Super ATV Disc Brake Kit-
-Uni Fliter-
-DPK Clutch Kit-
-Custom Snorkel-
-Jets-R-Us Jet Kit-
FloatingForeman is offline   Reply With Quote
Old 09-08-2010, 11:06 PM   #3 (permalink)
2003 foreman es's Avatar
Default
Knocking may be bearings. Not sure. You can purchase bearings seperate. Smoking may be rings, like FloatingForeman said. Here is a link to show what you have....
03 Foreman ES
Too much to list...
2003 foreman es is offline   Reply With Quote
Old 09-08-2010, 11:13 PM   #4 (permalink)
Honda Lover
Default
the noise Also could be too much clearence between the piston and the cylinder aka piston slap
-Honda Rancher 350-
-Wiseco Piston-
-Uni Fliter-
-DPK Clutch Kit-
-Custom Snorkel-
-Jets-R-Us Jet Kit-
Old 09-08-2010, 11:44 PM   #5 (permalink)
Default
The noise is coming from the bottom of the engine?
03 Foreman ES
Too much to list...
Old 09-09-2010, 12:21 AM   #6 (permalink)
foreman480's Avatar
Default
that does sound like a rod bearing i couldnt tell you for sure without seeing it. it could also just need a new timing chain. but once agin not for sure. butif it is a rod bearing you really need to replace the crank and rod too unfortunately
'95 foreman 480---SOLD!
looking for the next one might have to go to the dark side (non honda)
foreman480 is offline   Reply With Quote
Old 09-09-2010, 07:35 AM   #7 (permalink)
Default
I think you maybe right. Just have to pull it apart and see what ya got.
03 Foreman ES
Too much to list...
Old 09-09-2010, 09:01 AM   #8 (permalink)
Honda Lover
Shutitdotnet's Avatar
Default
Let me know what ya get I've had a loud ass ticking metallic noise coming from my top end I'm leaning towards a loose timing chain slapping because when it gets a little higher in the RPM range it seems to go away
06 Rubi
26" Mudlite XLs (soon to be 28" Silverbacks, if I keep this thing)
Snorkel
HL 2" Lift
05 400AT spawn child of satan - Sold That SOB
Shutitdotnet is offline   Reply With Quote
Old 09-09-2010, 12:47 PM   #9 (permalink)
foreman480's Avatar
Default
Quote:
now that sounds like a loose timing chain.
Old 09-09-2010, 01:13 PM   #10 (permalink)
Honda Lover
Default
Does anyone know if there is a "special" honda tool I'm going to need to remove the tensioner or the chain itself, in my book it shows a tensioner stop tool, is that something I can get off the shelf somewhere around here ??
06 Rubi
Snorkel
HL 2" Lift
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
