Transmission noise - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 12 (permalink) Old 09-27-2008, 01:42 AM Thread Starter
Transmission noise
Has anyone had the ratcheting noise on their rubicons, when decelerating down-hill? I have a 2004 rubicon and it whines/grinds only down-hill when the throttle is released. When the quad comes to the bottom of the hill and is coasting slowly the noise starts to sound like a chian that has come off track but the noise is gone after the throttle is pressed slightly.
Mopar or NO CAR!
cliff668honda is offline
post #2 of 12 (permalink) Old 09-29-2008, 10:45 AM
I am having the same problem with my 2005. I would appreciate some input as to what it might be. My thoughts are "oil chain"? But I'm not sure.
BTW, I have 6,500 miles on mine.
Rubicon1963 is offline
post #3 of 12 (permalink) Old 09-29-2008, 02:21 PM
Honda Addict
i know i can hear grinding and odd sounds when going down hill when my back wheels lock up??? could this be it
07 Rubi
Kimplex bumpers
27"XTRs
14'ITP ss106
Moose skids
rubidubi is offline
post #4 of 12 (permalink) Old 09-30-2008, 12:08 AM
tranny trashed.......start lookin
Wheres the riding at in western KY?
2007 rubicon
27x14 mud lite xtr
HI OUTPUT Right thumb
cavhooah is offline
post #5 of 12 (permalink) Old 09-30-2008, 07:53 AM
sounds more like a sprag/one way bearing in the clutch... check that first... its much much much much cheaper.... does your engine breaking still seam to work??
2007 420 Rancher
2" Lift
27" ZILLAs
ITP 12" Wheels
Stick Guards
HMF Programmer
HMF Utility Exhaust
Rear Bumper
surelly09 is offline
post #6 of 12 (permalink) Old 09-30-2008, 09:13 AM
Honda Mech?? Any suggestions...
post #7 of 12 (permalink) Old 09-30-2008, 09:33 AM
other guy is right, sprag clutch is what the problem is. part is about $100.00, remove the oil cooler, front case cover, clutch, change sprag and make sure you put it back in the proper way, and go hit the next whole.
07 Honda Rubicon
HL Clutch Kit
Mud Buster Cam
HMF Pipe
Custom Radio Box
Jet Kit
HL Springs
HL Lift
Recoil Cover
Custom Snorkel and all vent lines ran to snorkle
28" outlaws
gorilla axel!
Hot wired fan to switch
rear wheel spacers
HL temp gauge
HL full skid plate pachjage
new strong made rear bumer
heat guard
hondaman5002002 is offline
post #8 of 12 (permalink) Old 09-30-2008, 09:44 AM
Are we all talking about the same problem here. My question is what is causing the "chain rattle". Is that coming from the sprag clutch? Thanks
post #9 of 12 (permalink) Old 09-30-2008, 02:48 PM Thread Starter
I found the problem with mine. I had low oil pressure @ idle so I replaced the oil pump and the problem is solved. Honda redisigned the oil pressure relief valve in the pump after 2006.
The noise sounds like a chain rattle but it was actually the transmission pump pistons slapping the swashplate inside the transmission.
Mopar or NO CAR!
post #10 of 12 (permalink) Old 10-08-2008, 11:12 PM
So how hard is the oil pump to replace.
05 500 Foreman 27's DGL snorkeld (OLD)
04 450 Foreman 29.5's, GR, Rubicon Shocks, Snorkled, Clutch Kit, Tractor Muffler (OLD)
2016 Rubicon FM Snorkeled, Rad relocate, 28 s/w Backs SS wheels (NEW)
[l_,[____],
l---L -[]lllll[]-
()_) ()_)---)_)
MEMBER # 67
I HATE IT WHEN MY BELT GETS WET, USUALLY MY NUTS DO TOO!!!
bnjeep is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
