#1 (permalink) |
My 01 Rubi goes right into safe mode when I try using ESP to shift. I've cleaned the control motor, greased the conectors, checked and sealed the angle sensor and tightened a loose gear shifter pivot. What else am I missing. I just got this machine and it runs great with this exception. This Rubi only has 1174 miles on it. I don't need the ESP I just want to make the bike work right. Any help is greatly appreciated.
Jim |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Mine did something like that and I took it to the shop and they plugged it in a cleared the computer and reset the codes it fixed mine.
2002 Honda Rubicon: HMF utility series exhaust jet kit K&N air filter w/ outerwears pre filter 26" AMS Swamp Fox Plus tires 1985 Honda fourtrax 250 2wd: stock |
#3 (permalink) |
Honda Addict
you dont have to take it to a shop to check and clear the codes. its a pretty simple process ill try to scan my shop manual and pm it to you
06 Rubicon 27x9x12 Swamp lites Front 27x12x12 Swamp lites Rear Snorkeled/Vented Warn 2.5ci Bored .020 over Perfex Lift HL Clutch Kit HL Springs HMF Eco System Jetted Uni air Filter IGK Iridium Fan Switch |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
