oil pump chain??? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 11 (permalink) Old 02-05-2007, 10:17 PM Thread Starter
Honda Addict
Send a message via AIM to aaanma666
oil pump chain???
I thought i blew the tranny on my rubi but thanks to Honda Mechanic i found the problem. He told to check the oil pressure and i had none so i pulled the front crankcase cover off and the chain that drives the oil pump some how poped. Does anyone know how that could possibly happen?? Is there supposed to be a tensioner on there??
Thanks Honda Mechanic!
The good news is that it still runs and shifts great now that i put it back on but im afraid that it will happen again now. I dont think it did any damage.
06 Rubicon
27x9x12 Swamp lites Front
27x12x12 Swamp lites Rear
Snorkeled/Vented
Warn 2.5ci
Bored .020 over
Perfex Lift
HL Clutch Kit
HL Springs
HMF Eco System
Jetted
Uni air Filter
IGK Iridium
Fan Switch
aaanma666 is offline
post #2 of 11 (permalink) Old 02-05-2007, 10:35 PM
How many hours/miles is on yours, after reading posts in differant forums I'm starting to worry that I might have promblems with mine. I'm starting to wish I had bought a Foreman. Have you had any other problems?
06 Rubicon
Irishjig is offline
post #3 of 11 (permalink) Old 02-05-2007, 11:36 PM
Honda Addict
Send a message via MSN to Rubicon_Joey
Had it happen to my 04 rubicon. Took it to the dealer to have it checked out. They said the only thing they could think of to cause it to come off was that the crank was out of round or something of the sort. So they replaced the crank, pistons, rings...etc...pretty much reubuilt the bottom end and replaced the oil pump chain. Still not sure why it done it, but no problems yet, but then again its only had about 10-15 miles sicne then.
Parts for sale!!!(Just click red words)
04 Red Honda Rubicon.....28X10 & 28X12 Maxxis Zilla's....Mud Buster Cam...2'' lift......EPI Clutch Kit...MSA Tork Wheels...HMF Utility series...Dyno Jet Kit...K&N Air Filter...Warn: 3.0 ci, bumper and 424 select...Detriot Gearless Locker...H/L Disc Brakes
Rubicon_Joey is offline
post #4 of 11 (permalink) Old 02-07-2007, 03:25 PM Thread Starter
Honda Addict
its got about 250 miles and 75 hours which i didnt think was that much its only about 7 months old. I think my warranty if void because i blew the motor from suckin in water so honda wouldnt cover that in warranty so i rebuilt it myself. I think that im going to buy a new chain i hoping that maybe the old one was just strected or something
06 Rubicon
Snorkeled/Vented
Warn 2.5ci
Bored .020 over
Perfex Lift
HL Clutch Kit
HL Springs
HMF Eco System
Jetted
Uni air Filter
IGK Iridium
Fan Switch
post #5 of 11 (permalink) Old 02-08-2007, 10:56 PM
eric's Avatar
I think you should talk with Honda Mech, I'm sure he can give you some good advice. Are you sure your motor blew because of water or was it due to lack of oil ...............
2006 500ES
w/ some stuff...
eric is offline
post #6 of 11 (permalink) Old 02-09-2007, 05:25 PM
Honda Mechanic's Avatar
The chain that runs the oil pump is not very big and it has no guide or tensioner ,so when it starts to stretch it doesn't take long before it's quite loose ..
Here's a couple of pictures of an oil pump chain off a Rubicon which is at the shop now for a transmission ...
As far as no warranty on your 2006 bike .. Your dealer could have covered it under warranty ..
Honda Mechanic is offline
post #7 of 11 (permalink) Old 02-09-2007, 05:59 PM
How many miles/hours before we need to check them
06 Rubicon
Irishjig is offline
post #8 of 11 (permalink) Old 02-09-2007, 06:49 PM
The chain in the pictures has 1570km on it .. The bike had 15 lb. at idle and 55 lb. at 5000 rpm , it's getting a new hydro transmission , oil pump & oil pump chain ..
The chain wasn't really, really bad , when installed it would push back & forth about 3/8" ...
Here is a picture of the chain (I took it with my camera phone) you can see the little slack in the chain .. I don't know why Honda didn't have a nylon track type guide for it to run in ..
If I had a Rubicon I'd change it every 2-3000 miles .. They are easy to change it's just a matter of pulling the centrifugal clutch ..
post #9 of 11 (permalink) Old 02-09-2007, 07:10 PM
Send a message via MSN to big_daddy_bigfoot Send a message via Yahoo to big_daddy_bigfoot
I'm soooo glad I bought a foreman 500 now!!
2005 500 ES
K&N + pre filter
Jetted
Hmf piped
Highlifter springed
Highlifter boot guarded
Prefex long traveled
Itp type 7 blackouted
Itp 27 Mudlited
Carb vent modded
Kimpex rear bumpered
3000 lbs Gorilla winched
Roped w/custom rope stopper
Audio piped
and Ipoded.
big_daddy_bigfoot is offline
post #10 of 11 (permalink) Old 02-09-2007, 08:26 PM
Thanks for the info, I'll be sure to change it(maybe even at 1000 miles just to be safe). It sure is nice to have knowledgable people to get advise from.
06 Rubicon
Irishjig is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
