2004 Front Brakes - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 5 (permalink) Old 11-15-2006, 08:08 PM Thread Starter
Honda Addict
2004 Front Brakes
Hello, I'm about to take apart the front brakes on my 04' Rubicon. My question is my Hydraulic front lever has nothing, it goes all the way to the grip. I've bled it several times and am confident theres no air at this point. I just purchased this machine and was told that new shoes were just installed, which I'm doubting now , and that it was air in the line. So I tried adjusting the front adjusters and noticed that one would only turn 2-3 clicks either way and all the others seemed to move fine. Im going to pull it apart to check the cylinder but if I need to change one am I supposed to change all? Also, when I take this apart I've read that I need to replace the 4 bolts? Can I just Loctite these or is there some other reason to replace? Finally is it also a good Idea to replace the water/dust seal or is that also only if its bad or damaged. I appreciate any help before I do this. Also if I should know anything else that may help please let me know.
Thanks,
Ron
Spend it now, Can't take it with you. Let your kids make there own or they'll never learn.
2003 Rincon -
3k Venom Winch
Tow Hitch
2004 Rubicon-GPS -
2.5k Warn Winch,
Warn 424,
Moose Plow,
Xtreme Disk Brakes,
26x9 Front 26x12 Rear Bear Claws
1986 FatCat TR200 2-Wheel ATV
STOCK
CardRon is offline
post #2 of 5 (permalink) Old 11-16-2006, 11:03 AM
Honda Addict
Send a message via Yahoo to KAGRIFF
the master cylinder are also known for having to be rebuilt. will the brakes pump up at all or is there nothing ever there? as for the bolts I just reloctite mine and have had no problems. the seals i would replace only if i find a nick,cuts or appear to have leaks. Also pack the front bearing hub with grease when you go back together. I know the bearing are sealed but the grease will keep water out of the hub area. that water sitting in there will just make the bearings go that much faster.
09 Foreman 500 ES
07 foreman 500 ES "gone but not forgotten"
26" swamp lites
hmf
k&N
jetted
custom front bumper
KAGRIFF is offline
post #3 of 5 (permalink) Old 11-16-2006, 04:27 PM Thread Starter
Honda Addict
Thanks for the info, I'll be sure to pack the grease (makes sense). As for the Master Cyl/brake lever, it will pump up and hold, takes about 4 pumps to get about 1/2 - 3/4 full lever which is about where it shoudl be on the first pull. Anyway because its been raining on and off here I decided to wait until the w/e to do this, so any additional advice is greatly appreciated.
Ron
2003 Rincon -
3k Venom Winch
Tow Hitch
2004 Rubicon-GPS -
2.5k Warn Winch,
Warn 424,
Moose Plow,
Xtreme Disk Brakes,
STOCK
CardRon is offline
post #4 of 5 (permalink) Old 11-16-2006, 05:07 PM
Honda Addict
check the front bearings. the play that they get when they go bad allows the drum to push the wheel cylinders back. causing you to have to pump up the brakes to get any. bearing are known fro going bad. worse when you have changed to nonn stock tires as most of us has done.
09 Foreman 500 ES
26" swamp lites
hmf
k&N
jetted
custom front bumper
KAGRIFF is offline
post #5 of 5 (permalink) Old 11-16-2006, 07:17 PM Thread Starter
Honda Addict
I'l' take a look, but tires are still from when new and machine has 215 miles on it. Can the bearings be bad so quickly? When I had the front end raised up when installing the 424 kit I didn't notice any play in either tire. Thanks for the help.
Ron
2003 Rincon -
3k Venom Winch
Tow Hitch
2004 Rubicon-GPS -
2.5k Warn Winch,
Warn 424,
Moose Plow,
Xtreme Disk Brakes,
STOCK
CardRon is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
