INSTALLING CLUTCH KIT NEED HELP!!!!!!!!! - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 7 (permalink) Old 04-23-2006, 10:49 AM Thread Starter
IM FIXING TO INSTALL MY CLUTCH KIT AND I MIGHT BE RUNNING INTO A PROBLEM. THE INSTRUCTIONS SAY I NEED A CLUTCH TOOL FROM HONDA THE GUYS IN HERE THAT HAVE THEM LET ME KNOW WHAT THEY DID TO INSTALL THEM AND IF THERE IS AN ALTERNATIVE WAY OF DOING IT THANKS
_________________
06 RUBICON 26"ITP MUDLITES,ITP TYPE 6 WHEELS,HL CLUTCH KIT,DYNO-JET KIT,HL 2" BLOCKS,HL 1" SPRINGS,HL A ARM GUARDS,ACREBIS HAND GUARDS, BASKET FRONT W/ 12" DROP REAR,CUSTOM BRUSH GUARD
GITRDUMB82 is offline
post #2 of 7 (permalink) Old 04-23-2006, 02:31 PM
Send a message via AIM to MAD MUDDER Send a message via Yahoo to MAD MUDDER
if you talking about installing the springs, its farly simple. i just used a screw driver BUT, do not over strech the springs or they will not work as good.
-Aaron
03 400ex- renthal handlebars,Oury grips, LSR brake block, LSR bearing carrier, DG full skids, DG bumper, DG grab bar, white brothers exhaust, dynojet kit, K&N filter, SKIN graphics, SKIN gripper seat 15/45 sprockets, razr2 tires
06 brute force 650i---FOR SALE--- PM me if interested
CRACKIN' FRAMES & TALKIN' NAMES
MAD MUDDER is offline
post #3 of 7 (permalink) Old 04-23-2006, 06:13 PM
Re: INSTALLING CLUTCH KIT NEED HELP!!!!!!!!!
QUOTE ("GITRDUMB82":1jz36rn8)
_________________
Look in the "How To" section for the write-up on installing a clutch kit. If you stand the bike on end it it "farely" easy to install the new springs w/o removing the clutch and needing that tool.
2005 Honda Foreman 500 ES
The kitchen sink is on backorder...
Truegrit is offline
post #4 of 7 (permalink) Old 02-23-2007, 01:58 AM
JeffreyS84
Guest
Posts: n/a
That is incorrect. You MUST remove the clutch on a Honda Rubicon to change the springs. The rubicon's clutch springs are hidden inside the clutch behind a plate. You don't have to remove the clutch on a foreman 450. You have to use a honda or epi clutch puller to remove it. A 2 or 3 jaw gear puller will NOT work. The honda puller costs $70 and takes 7-10 days to order. Honda tools take longer to order than do the honda parts. Just load your quad on a trailer, take it to a honda shop, and let them use their puller on your bike. When you get to the point where you take the oil tank off, it is time. When you get to the honda shop, remove the case bolts, remove case, let them use an impact, let them pull clutch, change the springs and impact the clutch on, put case on, hand tight bolts, take home and finish. Many people do this. Should cost less than $30 for them to do that much work.
FYI - You either have to use an impact wrench or the proper Honda clutch holder tools to remove the 27mm nut that holds the clutch on before you pull it. Also, you need to replace that $5 nut since you have to unstake it. You can not restake that nut.
post #5 of 7 (permalink) Old 02-25-2007, 11:01 AM
Honda Addict
Send a message via AIM to aaanma666
where did you find the clutch kit for an 06 i couldnt find one
06 Rubicon
27x9x12 Swamp lites Front
27x12x12 Swamp lites Rear
Snorkeled/Vented
Warn 2.5ci
Bored .020 over
Perfex Lift
HL Clutch Kit
HL Springs
HMF Eco System
Jetted
Uni air Filter
IGK Iridium
Fan Switch
aaanma666 is offline
post #6 of 7 (permalink) Old 02-25-2007, 11:16 AM
Honda Lover
Send a message via AIM to justinwilliamskx
the springs on a 450 are bhind a plate too you just remove the eclips to get at them
1999 foreman 450s 4x4
moose lift snorkled moose floorboards front and rear tow points cliped carb spring 25" dirt devils on stock foreman wheels 28" mudzillas on stock rubicon wheels EPI clutch kit fo-14 135 oem jet custom skid and bash plate drilled carb slide and one hevy duty gorilla cv gear reduction
justinwilliamskx is offline
post #7 of 7 (permalink) Old 02-25-2007, 11:43 AM
Honda Mechanic's Avatar
The centrifugal clutch springs on a TRX500FG/FA Rubicon are on the inside so the centrifugal clutch must be pulled to change them ..
Here are a couple of pics of the clutch .
Honda Mechanic is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
