Another Rancher ES Shifting Problem - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 02-21-2012, 09:14 PM   #1 (permalink)
Default Another Rancher ES Shifting Problem
I've searched the forum and could not find anyone who has had my exact problem so I thought I would ask.
I have a 2004 rancher with 378 miles, thing is like new. When you shift it into first gear with the electric shift, the display will show "1" and then "--" and the rancher will not move. If I give it some gas and continue to press the upshift button it will eventually take gear and stay in for a while, but it usually slips into neutral when I let off of the gas. When am moving along sometimes I can shift into second and third but I have to shift several times to get it to stay in gear. I have not been able to get past third gear. Downshifts with electric shifter and always goes into reverse. There is no grinding of any sort.
It does the exact same thing with the back up manual shifter.
I pulled the front cover off. Everything looks good the best I can tell. Shift plate looks good, shift drum star doesn't have any broken ears. Does anyone have a clue about what else I can check next? Not sure if it is normal but it looks like the outer centrifugal clutch has been hot at some point as it is discolored in places.
Thanks in advance.
04_rancher is offline   Reply With Quote
Old 02-21-2012, 09:20 PM   #2 (permalink)
Super Moderator
h22ate's Avatar
Default
Wonder if you have a bad shift angle sensor? That same thing happened to my buddies but he never tried it with the foot shifter. I know that fixed his problem though.
08 Rubicon
‚——P--;===ฑ--= <-
!‚–’ฏƒนถ
http://youtu.be/U71bn4ZF4K0
h22ate is offline   Reply With Quote
Old 02-21-2012, 09:22 PM   #3 (permalink)
Administrator
toodeep's Avatar
Default
Welcome, the clutch drum color is normal. Check the shift plate really close for a crack. Try shifting it with the tool and watch the stuff to see what it is doing. If you just have a crack it should be more noticeable when pressure is on it.
Here is one that is broke...
A 420 and 300 with some stuff...
toodeep is online now   Reply With Quote
Old 02-21-2012, 09:28 PM   #4 (permalink)
rich450es's Avatar
Default
welcome to the forum !
2000 foreman 450 es-s
the f**king pig
SOLD!
honda forum.com stickers for sale .....pm me for details !
Old 02-21-2012, 10:06 PM   #5 (permalink)
Default
I thought about the angle sensor, but since it did the same thing with the manual shifter I started looking at the mechanical part of it. I put pressure on the shift plate with the manual shifter and I didn't see any separation. Could the shift plate be worn so much that it will not function properly? I wouldn't think that with 378 miles this would be the case but who knows.
The only thing about the shift plate that I see at all is that there is a polished edge on two parts of the shift plate. Now since I have never seen a shift plate before this one I can't 100% say that this one is fine, but it is not what I would expect to see from the plate fracturing. That and I have not seen any broken pieces floating around in the case.
It is just odd to me that when you give it more throttle it seems to shift better. I have already adjusted the clutches.
Old 02-22-2012, 11:56 PM   #6 (permalink)
Default
Figured out the problem. The arm that holds the shift drum center(the star shaped piece on the shift drum) in place once a shift has been made, has a bolt that holds it in place. The bolt was loose. Tightened it up and all seems to be working like it should. This explains why it would not hold a gear.
Old 02-23-2012, 12:01 AM   #7 (permalink)
rich450es's Avatar
Default
glad you got it fixed ....and cheep too lol
the f**king pig
SOLD!
Old 02-23-2012, 12:02 AM   #8 (permalink)
tskfreak's Avatar
Default
that must have been a good feeling!!!! welcome to the forum
2012 FOREMAN 500 ES
27 INCH ZILLA'S
ITP SS212'S ALL BLACK WHEELS
1.5 INCH STI ALUMINUM WHEEL SPACERS
BIG GUN EXHAUST
TWIN AIR FILTER, K&N OIL FILTER
ALUMINUM PRODUCTS SKID PLATE
POWERMADD STAR SERIES HANDGUARDS
MOOSE OZARK REAR BAG
4 INCH PVC STORAGE COMPARTMENT
tskfreak is offline   Reply With Quote
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
