is this a head gasket leak? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-05-2012, 02:19 PM   #1 (permalink)
Default is this a head gasket leak?
I am not so ATV-tech savy, but my best guess here is that my 2000 Rancher ES needs a new head gasket.
I noticed the oil at the top of my cylinder head, what do you guys think?
egoprofit is offline   Reply With Quote
Old 01-05-2012, 02:31 PM   #2 (permalink)
rich450es's Avatar
Default
thats just the rocker box (valve cover) leaking! the nuts are eather loose or you need to replace the steel gasket
2000 foreman 450 es-s
the f**king pig
2500lb warn winch
foreman 450 parts for sale
pm me for info
Old 01-05-2012, 02:35 PM   #3 (permalink)
sspeckerwood's Avatar
Default
i would have to agree with ya rich. make sure you get some yamabond when installing the new gasket. it makes for a really good tight seal
2012 TRX500FM FOREMAN.
SSPECKERWOOD 3RD HEADLIGHT MOD
QUAD BOSS REAR SEAT
26" SWAMPLITES
KFI #3000 WINCH
HOT GRIPS HEATED GRIPS & THUMB WARMER
HONDA ALUMINUM A-ARM GUARDS
00' FOREMAN 450es
HIGH LIFTER SPRINGS FRONT & REAR
MAXXIS TIRES OFF A 2012 FOREMAN 500
http://www.flickr.com/photos/sspeckerwood/
http://www.youtube.com/user/sspeckerwood
Official hondaforeman.com stickers
IF YOU WOULD LIKE OFFICIAL HONDAFOREMAN.COM STICKERS PM ME.
sspeckerwood is online now   Reply With Quote
Old 01-05-2012, 02:37 PM   #4 (permalink)
Send a message via AIM to scottl1346
Default
id replace the valve cover gasket its 4 bolts the cover pops off clean the 2 surfaces good put in new gasket and don't over tighten them they only need to be a little more then hand tight or you will end up with a helicoil like me lol
02 foreman 450 ES
2 inch HL lift kit
super ATV front disk brake conversion
27 inch Zillas
14% gear reduction
HMF ECO system exhaust
diamond plate bash plate and cv boot guards
Super-winch 1500lb winch will upgrade someday lol
custom LED brake lights
scottl1346 is online now   Reply With Quote
Old 01-05-2012, 02:39 PM   #5 (permalink)
Administrator
toodeep's Avatar
Default
Looks like the head nut/stud might be leaking, pretty clean around it anyways. I've had them before where the stud pulled the threads in the case and it would leak like that. You could check and see if the nut is tight (about 30 ft/lbs).
toodeep is online now   Reply With Quote
Old 01-05-2012, 02:51 PM   #6 (permalink)
Default
Thanks guys, at least I may be right about the "gasket" part. haha
This quad only has 1,050 miles on it, so I'm really hoping it is just the gasket and not an issue with the stud pulling threads. I'll check the tightness and order a gasket if it isn't the problem.
Any suggestions on where to get a cheap gasket?
Old 01-05-2012, 02:58 PM   #7 (permalink)
Default
dealer for the one or if you want to get a whole topend set id get it off ebay. prob 10 to 15 bucks at dealer for the one and about 25 off ebay for the whole topend set
02 foreman 450 ES
2 inch HL lift kit
27 inch Zillas
14% gear reduction
Old 01-05-2012, 03:08 PM   #8 (permalink)
Administrator
toodeep's Avatar
Default
Pull it off and spray paint or RTV it and put it back together. You did say cheap correct?
Old 01-05-2012, 03:10 PM   #9 (permalink)
rich450es's Avatar
Default
Quote:
a very thin layer of hondabond works good too
the f**king pig
2500lb warn winch
pm me for info
Old 01-05-2012, 06:12 PM   #10 (permalink)
Default
you could also try some double sided sticky tape lmao
02 foreman 450 ES
2 inch HL lift kit
27 inch Zillas
14% gear reduction
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
