Rear axle problem! - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 12-12-2011, 12:40 PM   #1 (permalink)
Default Rear axle problem!
I just got this 06 rancher 350 and the guy before stripped the threads on the axle shaft so he welded the nut to the axle and hub. Can I take apart the other side an slide the axle out that side and is there any clips holding the axle in place I'll need to take off to do that? Also what size socket do I need for that nut bc I don't have it in my tool box and gonna have to go pick one up. Thanks for any input.
csmyj is offline   Reply With Quote
Old 12-12-2011, 12:41 PM   #2 (permalink)
Default
Oh I forgot to say I'm doing this so I can change the rear brakes.
Old 12-12-2011, 12:52 PM   #3 (permalink)
redneckdude120's Avatar
Default
your gonna have to replace the axle. and take a grinder and cut the nut off.
2005 Honda Rubicon 500
27" Vampires on stock wheels
HMF Performance
Snorkeled
Diamond Plate Bash Plate
Strong Made CV Boot Guards
Summit 3500lb Synthetic Winch
Highlifter 2" lift kit
Rhino-lined racks and bumper
Custom bumper
redneckdude120 is offline   Reply With Quote
Old 12-12-2011, 12:59 PM   #4 (permalink)
Default
So I can't just take everything off the one end that's not welded up and slide the axle out through the other side??? I didn't think it mattered what side it came out of, just didn't know if there is any type of clips in there that I would have to take off before sliding it out?
Old 12-12-2011, 01:00 PM   #5 (permalink)
Administrator
toodeep's Avatar
Default
The brake side hub is welded on? If so your going to have to replace the axle (30mm on those nuts BTW).
toodeep is online now   Reply With Quote
Old 12-12-2011, 01:01 PM   #6 (permalink)
rich450es's Avatar
Default
there are no clips holding the axle in
2000 foreman 450 es-s
the f**king pig
2500lb warn winch
foreman 450 parts for sale
pm me for info
Old 12-12-2011, 01:19 PM   #7 (permalink)
Default
The brake side nut is welded to the axle shaft and hub I can grind othe weld off and save the hub but the threads are stripped on the axle. I'm trying to just get it on the trails right now so if I can slide the axle out with everything still on that one side change the brakes for now so I can ride then find another axle and stuff later? Would that work will the axle slide out the brake drum side? I'll try and get pics posted later. But I don't see it being any problem to do that bc I've done it will sport quads but this is my first 4x4 utility and wasn't sure if I'm trying some that isn't possible and just going to frustrate myself? lol!
Ps thanks todeep.
Old 12-12-2011, 04:23 PM   #8 (permalink)
sspeckerwood's Avatar
Default
you have to get the hub off. thats the way the axle comes out
2012 TRX500FM FOREMAN.
SSPECKERWOOD 3RD HEADLIGHT MOD
QUAD BOSS REAR SEAT
26" SWAMPLITES
KFI #3000 WINCH
HOT GRIPS HEATED GRIPS & THUMB WARMER
HONDA ALUMINUM A-ARM GUARDS
00' FOREMAN 450es
HIGH LIFTER SPRINGS FRONT & REAR
MAXXIS TIRES OFF A 2012 FOREMAN 500
http://www.flickr.com/photos/sspeckerwood/
http://www.youtube.com/user/sspeckerwood
Official hondaforeman.com stickers
IF YOU WOULD LIKE OFFICIAL HONDAFOREMAN.COM STICKERS PM ME.
sspeckerwood is online now   Reply With Quote
Old 12-12-2011, 05:10 PM   #9 (permalink)
Administrator
toodeep's Avatar
Default
Are your brakes shot? If you can get the hub off then replacing the shoes will be easy, then just weld your hub back on for the time being.
Old 12-12-2011, 05:33 PM   #10 (permalink)
Default
Yea brakes are done it doesn't have any pedal. If there are no clips or anything holding the axle in what's it matter on which side it comes out? I might be able to grind the welds off but if I do that I'd rather go ahead and replace so I don't have to go back through the trouble again later.
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
