#11 (permalink) |
Administrator
The axle is held in (in part) by the brake panel. To remove the axle the brake panel has to be taken off. That will not help you though for what your wanting to do. Bearings is what is holding the axle in place (which have snap rings holding them in) and a shoulder built onto the axle rides against the bearing keeping it from getting pulled form either direction, it only comes out the brake side after the brake panel is removed.
| Sponsored Links | |||
Advertisement | |||
#12 (permalink) |
Welcome to the forum dude!!!
05 Green Foreman
DGL,2"SS-Lift Plano green hunting box heated hand grips and thumb warmer carb mod ,Kolpin hitch,GPS bracket rattle can camo stock rims with 28" Zillas 11 Green Rubicon Gscape,power steer Warn 2500,Cycle Country 54" blade crappy stock tiers Kolpin hitch http://youtu.be/i9MhWDPUDHo |
#14 (permalink) |
The rear hubs on my 89 300 foretrax have been both welded for years. When I changed the brearings or brakes I just ground off the weld and then rewelded them. You should be good.
2006 Foreman 4x4 500s Powermadd handguards 2.5 Warn winch 2" Perfex long travel lift kit High Lifter springs 26-12-12 Executioners on rear 26-10-12 Executioners on front Douglas Rattlesnake rims 3rd Headlight switch Moose Heated Handgrips and thumb warmer Garmin Legend gps Replaced the stock silver engine covers and front skid plate with 07 camo black and painted front brush guard black 2005 Rancher 350ES 2wd 2001 Polaris 325 Trailboss 2wd |
#15 (permalink) |
Administrator
Once you get it off you might be able to chase new threads onto it and save yourself some money. It could be metric or standard depending on what you have around. A finer thread pitch will hold the best though.
#16 (permalink) |
Yea the only thing is I didn't weld it and not sure how good of a bead he layed but will did out lol! I just got my lift, wheels and tires and snorkeled it and I'm liking te looks alot so now that it's back together I can take it to my buddies shop and work on that axle.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
