#1 (permalink) |
Hey guys i've seen other threads on here that helped others so i joined up today tosee if i can get some insight on my problem.Alright ive been workin little bit on a 04 rancher 400at recently and ive nevr worked on newer 4x4 quads like this i cleaned the carb which also means i disconnected the tp sensor and throttle cable, i checked the codes and the esp is throwing code 4 which i believe to be the tp and the 4wd is throwing code 4 for voltage my question is there a specific way that i was supposed to put the tp sensor back on or do i have to reinitialize it just because i took it off to clean the carb
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Since you unplugged the TPS, you will need to perform the initialization procedure. Also, since you're getting the system voltage code, make sure you have a good battery and that it's fully charged.
2000 Foreman 400 2004 Grizzly 660 Both stock, except for Mudlites and Kimpex rear storage box. |
#3 (permalink) |
welcome to the forum rancherat04!
#5 (permalink) |
Welcome to the forum,
F&AM Rockwell 191 PM 08 Foreman ES Camo XTREME 2" lift 26in Swamplites, ITP wheels Moose skid plate Tusk hand guards 1 1/2" wheel spacers 4" storage tube "Black" 2 50 cal ammo cans "Black" WARN XT2500 Hockey puck spring spacers 07 Recon ES Green 1 1/2" wheel spacers 2" lift Tusk hand Guards Rancher wheels and tires |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
