#1 (permalink) |
I have a 2002 Rancher 350. It will startup and run long enough to pull it out of the tailer then shuts off after about 3-4 minutes. Then will not start without starting fluid. Any ideas?
1999 Foreman 45ES 2002 Rancher 350FM Last edited by iceman71; 06-18-2011 at 04:32 PM. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
does it only run on choke? or just for a few mins no choke
BTW welcom to the forum
#3 (permalink) |
thanks for the welcome, it just stops running. I was thinking that the carb may be leaking off and might need cleaned.
This is my wifes quad so I really need to get it running soon.
1999 Foreman 45ES 2002 Rancher 350FM |
#4 (permalink) |
check the carb vent lines ,thay may be clooged with mud (i saw your pics ,realy stickey mud) . if not that pull the carb and clean it .also check the flow out of the gass tank (there is a screen in fuel tank that may be getting clooged)
.........RICH
#5 (permalink) | |
Quote:
Thanks for the info... do know what all year Rancher 350 carbs will fit an 02? Will an 06 work on it?
#6 (permalink) |
on the fm modals thay are different
try looking here this is the cheepest parts place Dirt Cheap Yamaha, Honda, & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
#7 (permalink) | |
Quote:
What's an FM model?
#8 (permalink) |
if you look on the left front frame rail it will tell you what model rancher 350 you have .there was 4 models under the parts look up.also you can find the model under the seat on rt side
#9 (permalink) |
TM = Two wheel drive, manual shift.
FM = Four wheel drive, manual shift. TE = Two wheel drive, electric shift. FE = Four wheel drive, electric shift.
2000 Foreman 400 2004 Grizzly 660 Both stock, except for Mudlites and Kimpex rear storage box. |
#10 (permalink) |
welcome to the forum
2012 TRX500FM FOREMAN. SSPECKERWOOD 3RD HEADLIGHT MOD QUAD BOSS REAR SEAT 26" SWAMPLITES KFI #3000 WINCH HOT GRIPS HEATED GRIPS & THUMB WARMER HONDA ALUMINUM A-ARM GUARDS 00' FOREMAN 450es HIGH LIFTER SPRINGS FRONT & REAR MAXXIS TIRES OFF A 2012 FOREMAN 500 SSPECKERWOOD 3RD HEADLIGHT MOD http://www.flickr.com/photos/sspeckerwood/ http://www.youtube.com/user/sspeckerwood Official hondaforeman.com stickers IF YOU WOULD LIKE OFFICIAL HONDAFOREMAN.COM STICKERS PM ME. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
