Oil Leak?? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 11-14-2010, 07:14 PM   #1 (permalink)
Default Oil Leak??
I have noticed an oil leak on the backside of my 02 rancher, right on the back side of the block, but my oil level hasn't dropped, any ideas on what might be the issue??
Thanks
crazyrunningkid is offline   Reply With Quote
Old 11-14-2010, 07:58 PM   #2 (permalink)
2003 foreman es's Avatar
Default
to the forum... We may need more info. Is it leaking, as your sitting on it, on the right or left side? At the gasket where the crankcase bolts to the rear crankcase(trans)?
03 Foreman ES
Too much to list...
2003 foreman es is offline   Reply With Quote
Old 11-14-2010, 08:20 PM   #3 (permalink)
Default
it looks as though the oil is leaking where the recoil attaches, no leaks when sitting, but after running it will leak. And as I had said before there has been no change in oil level.
Old 11-14-2010, 08:25 PM   #4 (permalink)
Default
That's a bit common. If you like, Retorque the bolt that connect the two halves of the crankcase together. That may help, but I've read several threads about that same thing.
03 Foreman ES
Too much to list...
Old 11-14-2010, 10:02 PM   #5 (permalink)
Honda Lover
350rancherboy's Avatar
Default
The seal behind the pullrope thingy, replace it, when that goes bad the mud thats been eating away at the seal will go into your motor and slowly ruin it!
Its like 5 bucks...a hour or 2 to fix, pull seat air box then pull recoil assy, under that theres a big thingy with a 17mm bolt, use an impact wrench with a BIG extension loosen that (it'll try to turn the crank) once that is loosen gently pry the seal off, get your new one, slob some grease (marine) on there and tap it in place gently, put back together, clean your pull rope assy and your done!
Or consider a block off plate or sealing up your pullrope asy.
ATVLESS
350rancherboy is offline   Reply With Quote
Old 12-21-2011, 04:44 PM   #6 (permalink)
Default
ok, so i have finally got around to fixing this oil leak, but i cannot remove the bolt in the center (the big one). I reefed on it pretty hard and tried an impact with no luck. Anyone have any tips on getting this off. Thanks
Old 12-21-2011, 04:47 PM   #7 (permalink)
sspeckerwood's Avatar
Default
i've always used a impact gun. with lots of air that will give you the torque burst you need.
2012 TRX500FM FOREMAN.
SSPECKERWOOD 3RD HEADLIGHT MOD
QUAD BOSS REAR SEAT
26" SWAMPLITES
KFI #3000 WINCH
HOT GRIPS HEATED GRIPS & THUMB WARMER
HONDA ALUMINUM A-ARM GUARDS
00' FOREMAN 450es
HIGH LIFTER SPRINGS FRONT & REAR
MAXXIS TIRES OFF A 2012 FOREMAN 500
http://www.flickr.com/photos/sspeckerwood/
http://www.youtube.com/user/sspeckerwood
Official hondaforeman.com stickers
IF YOU WOULD LIKE OFFICIAL HONDAFOREMAN.COM STICKERS PM ME.
sspeckerwood is online now   Reply With Quote
Old 12-21-2011, 08:15 PM   #8 (permalink)
lop3r1's Avatar
Default
Quote:
i noticed that you replied to this fella in a time-sensitive fashion!!! lol!!!
07 foreman s camo
2" hl lift
1" hl wheel spacers
27" outlaws
epi/hl outlaw clutch kit
hmf utility, uni filter, dynojet kit
3000lb superwinch
triangle snorkel kit
herculiner on racks/front bumper
custom front recovery point
lop3r1 is offline   Reply With Quote
Old 12-21-2011, 11:02 PM   #9 (permalink)
Default
Quote:
what do you mean by that?? lmao
QUAD BOSS REAR SEAT
26" SWAMPLITES
KFI #3000 WINCH
00' FOREMAN 450es
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
