rear brakes need adjusting//how?? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 10 (permalink) Old 05-01-2010, 09:31 PM Thread Starter
Honda Addict
laserdoc's Avatar
Are the rear brakes on a rancher as easy as just turning the wing nuts in to tighten them up. The fronts will stop me on a dime but the rears either need to be adjusted or replaced
03 rancher ES 2x4
K&N filter,Dynojet,HMF pipe
Mudlites rear and back
2500 pound winch
Suzuki 2006 eiger 4x4
3000 pound winch
laserdoc is offline
post #2 of 10 (permalink) Old 05-02-2010, 10:12 AM
2003 foreman es's Avatar
My 03 foreman es has adjusting wing nuts, inside of the right rear tire.
1 for the front,1 for the rear brakes. Just turn the adjuster so the rear tire spins a couple of times freely, then stops.( have to lift the rear of the bike). If the brakes need to be replaced, check out cheapcycleparts.com for a diagram of your rear brake system. Good luck...
03 Foreman ES
Too much to list...
2003 foreman es is offline
post #3 of 10 (permalink) Old 05-02-2010, 10:56 AM
Administrator
toodeep's Avatar
Garage
The top nut is for the park brake and the bottom is for the foot brake.
toodeep is offline
post #4 of 10 (permalink) Old 05-02-2010, 11:37 AM Thread Starter
Honda Addict
laserdoc's Avatar
park brake works fine.
I had my son pull in on the hand brake and the indicator is no where near the little triangle indicating that they need replacement.
Do I turn that bottom wing nut to adjust it on does it only control how much play is on the foot pedal and does not tighten up the brake itself???
03 rancher ES 2x4
2500 pound winch
3000 pound winch
laserdoc is offline
post #5 of 10 (permalink) Old 05-07-2010, 11:59 PM
Honda Addict
Sooner's Avatar
The hand lever and foot pedal actuate the same lever on the brake. There's no overall adjustment on the brake shoe lever, only the amount of free play in the cables for the hand lever and pedal. As stated above, the top wing nut adjusts the freeplay in the hand lever. This should be adjusted to give the lever a freeplay of 9/16" to 13/16" when measured from the end of the lever. The bottom wing nut adjusts the freeplay in the brake pedal. This should be adjusted to give you the same amount of freeplay as the hand lever when measured from the end of the brake pedal.
If the freeplay on both levers is set and the brake shoe wear indicator does not indicate worn brake shoes (as you've stated), the only other thing I can think of that would degrade your rear braking is water trapped in the drum. You can check this by pulling the drain bolt on the bottom/inside of the drum. If water comes out, then you probably need new seals.
Hope this helps.
2007 Suzuki King Quad 450 4x4 - 14" ITP SS112 wheels, 26" Bighorns, Xtreme 3" lift, RT2500 Winch, Twin Air filter, RAM GPS mount, Lowrance GPS, Plano ATV storage box, 2 - Playmate coolers and a RAM self-leveling beer holder
2010 Can Am Outlander 650 Max - 26" Bighorns, 200 watt audio tube by Sooner, BRP rear storage box
2007 Honda Rancher 420 4x4 ES (red), 14" ITP SS112 wheels, 26" Bighorns (Sold)
2007 Honda Rancher 420 4x4 ES (yellow), 14" ITP SS112 wheels, 26" Bighorns (Sold)
Sooner is offline
post #6 of 10 (permalink) Old 05-09-2010, 07:43 AM Thread Starter
Honda Addict
laserdoc's Avatar
Hope this helps.
Thanks for the hint. I will check it today
03 rancher ES 2x4
2500 pound winch
3000 pound winch
laserdoc is offline
post #7 of 10 (permalink) Old 05-29-2016, 10:02 PM
Bringing this topic back to the top...
'06 Foreman
Rear brakes need to be adjusted,
But the wing nut is frozen / rusted in place on the threaded stud.
Any suggestions on freeing up the wing nut..?
Drifthopper is offline
post #8 of 10 (permalink) Old 05-30-2016, 02:55 AM
Quote:
'06 Foreman
I like Kroil. A 50/50 mix of acetone & ATF will work, if you can't find Kroil. Soak it overnight and use heat on the nut if you have to. Coat it with LPS-3 or similar to keep from rusting again.
2008 420 Rancher manual shift. Rubicon alum wheels & tires (old style). RT 2500 Warn winch.
2015 500 Rubicon-manual shift, 3500SR Terra Superwinch.
Pipercub is offline
post #9 of 10 (permalink) Old 05-30-2016, 10:39 AM
mrbb's Avatar
Clean as much of the treads as you can first with a wire brush, or wire wheel, .
I would also add something to the above that was never mentioned.
Brake pads can get glazed over, and then they will not work as well.
They can be cleaned with sandpaper to deglaze them.
Most brake issues I find are from lack of folks cleaning them every so often and waiting till there is an issue, rather than doing a PM. On them once in a while. A few minutes once or twice a yr, can save a lot of time trying to fix a bigger issue ?
mrbb is offline
post #10 of 10 (permalink) Old 05-30-2016, 11:34 PM
Thanks Guys..!
Kroil is a staple in my garage, as is acidtone & atf ,
The kroil worked out well this morning, sprayed it on and about 15 minutes later was able to turn the wing nuts by hand.
While I was at it, took the cover off the rear drum, all was good inside, not grazed , put everything back together and adjusted the brakes.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
