350 es gear shifting problems - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 05-05-2009, 07:23 PM   #1 (permalink)
Default
Hi, i joined a couple of months back and posted a question and was helped straight away..hopefully someone can help me here please.
I have a 2003 350 es 2wd, i rebuild the clutch mechanism etc as when i bought it it was stripped down. the problem i am having with the bike is that it does not know what gear it is in.
I can change the gears fine with the foot shifter, but the thumb shifter doesnt work correctly and the dash shows all the wrong gears, it jumps from 1 to r then n then 3 for example........
i have changed the angle sensor but this has not cured the problem.
can anyone shen any light on what the problem may be?
thanks in advance
rory_mcw is offline   Reply With Quote
Old 05-06-2009, 10:26 AM   #2 (permalink)
Administrator
toodeep's Avatar
Default
If I have to guess I would say the gear position switch is bad (change switch assy). Located under the rear cover of the motor and a pretty common problem in my area with winter riding and short trips.
Old 05-13-2009, 06:16 AM   #3 (permalink)
Default
thank you, anyone else got any ideas?
ive checked manual and tested angle sensor - seems fine
cheers
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
