Rancher wont start (Clicking in Battery area) - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 13 (permalink) Old 04-27-2007, 12:46 AM Thread Starter
Send a message via MSN to ferghughes
I have a problem with my 06 rancher. The other day it wouldnt start on the button.. But went no problem with the pull start.
When the start button is pressed .. All I get is clicking under the seat in the battery area.. The battery is fully charged and all connections are tight.. Sometimes it starts with the button though !!!!
I am baffled .. Any ideas or someone that had this problem before...
Thanks alot
If in doubt.... Flat out !!!!
ferghughes is offline
post #2 of 13 (permalink) Old 04-27-2007, 01:11 AM
You probably need a new relay switch. More commonly known on your car as a starter solenoid. Should be able to find one for under $40.
Don't assume that is the problem - you need to check a couple of things, but 9 times out of 10 this is the problem when you hear that clicking but need to make sure it is not the starter. If you disconnect the cable attached to the starter and take a jumper cable (heavy gauge cable) and go straight from the battery positive to the starter terminal and touch the starter and it turns over, it is likely your relay switch.
Do you have a Clymer manual or a Honda Service manual? These manuals have the troubleshooting described in detail for these types of problems - usally makes it quicker to diagnose the problem and figure out what parts you need.
If it is the relay, this is an easy part to change yourself - no need to have it done by a dealer.
2006 Honda Rancher ES 350
25" XTR's on C-Series 7 Black
Warn 2.5ci w/synthetic rope
Warn Bumper, Driving Lights, and Back-up Light
Warn 424 Select
High Lifter 2" Lift and HD Springs
HMF QS1 Ecosystem
K&N Filter, Dynojet kit, Iridium plug
WildWildWest is offline
post #3 of 13 (permalink) Old 04-27-2007, 05:52 AM
Honda Mechanic's Avatar
Get a volt meter and put 1 lead to the post on the starter & ground the other lead , then push the starter button again .. If it has 12v going to the starter then it probably needs brushes ..
Honda Mechanic is offline
post #4 of 13 (permalink) Old 04-27-2007, 07:09 AM
Honda Lover
mudlord's Avatar
Send a message via Yahoo to mudlord
Mine was doing the same exact thing. What I did was clean the contacts on the battery real good with a wire brush, screw the treminals down, put a little grease on them and it worked great!
2002 Honda Foreman ES- DGL, HL Lift springs, Super ATV lift kit, Triangle ATV Snorkit, 27" Gators, Diamond plate bash and CV guards, K&N filter,Outerwears prefilter,XPATV Disc brake kit, reverse override mod, HL sealed bearings,Audio Tubes speaker system w iPod Otter Box
My Pics & Vids 1
My Pics 2
http://inlinethumb40.webshots.com/39...600x600Q85.jpg
mudlord is offline
post #5 of 13 (permalink) Old 04-28-2007, 01:22 AM
Honda Addict
when you here the click,tap on the starter with a hammer at the same time.if it starts ,you know you have a dead spot in the starter...if this doesnt work,your probly lookin at a relay issue...
dont sweat the petty things,pet the sweaty things.... 2000 450 es 26 mudlites,superwinch,50" plow.
fatsam is offline
post #6 of 13 (permalink) Old 04-28-2007, 06:46 PM
Send a message via Yahoo to rubyandforeman
check your positvie and negitves on the battary. cuz i had the same problem today..
2007 honda 450r its got some mods... but its still stock ppl think
2005 honda foreman es 4x4
with some mods
rubyandforeman is offline
post #7 of 13 (permalink) Old 05-03-2007, 09:25 AM
Send a message via AIM to repieces Send a message via MSN to repieces
My Rancher does the same thing your talking about, and it does it often. Once it would start clicking, I would take a screwdriver and loosen and tighten and move the battery cables around on the terminals. 100% of the time, it was the cable connections at the battery. Just do like Mudlord said and clean the battery posts and your cables real good and if that doesn't work, check your solenoid. You can take a pair of channel locks and jump across the positive and negative posts on the solenoid and if you starter engages when you do that, than your solenoid is bad.
2001 Rancher 4x4
25" Vamps
9.5" Fronts
12" Rears
HL Leak Shield
Strong Made Floorboards
HL Disc Brake Kit
Super ATV 2" Lift Kit
HL Lift Springs
Snorkeled
DGL
Warn 424
1.5" Spacers
EPI Clutch Kit
repieces is offline
post #8 of 13 (permalink) Old 06-11-2007, 01:28 AM
your solinaoid might have gone out
2006 Honda Rancher 400
Bracket Lift
26" 589s
12" ITP C-Series Type 7
Snorkel
Bored Out To A 425
monsterrancher4x4 is offline
post #9 of 13 (permalink) Old 07-22-2007, 09:31 PM
my wifes rancher is doing the same thing,but the battery is all ways about dry, no water, in it.The bike is a 2004, we have put 2 batterys on it all ready.you can put a charger on it and it will start after a couple of minutes,let it run for a while.then turn it off and leave it alone,come back later and it will just click.
2004 RUBICON HIGHLIFTER FRONT DISC BRAKES,HIGHLIFTER 2IN LIFT KIT,WARN WINCH,DETROIT GEARLESS LOCKER,HMF EXHAUST,K&N AIR FILTER,CUSTOM SNORLE,MUDBUSTER CAM KIT,GORILLA AXLES,WARN424,HEATED HAND GRIPS,28IN ITP MUDLIGHTS,MAXXIX 8 SPOKE WHEELS,FENDER KIT, CLUTCH KIT, FULL BODY SKID PLATE,BORED 50,HIGHLIFTER SPRINGS
heat-air is offline
post #10 of 13 (permalink) Old 07-22-2007, 09:32 PM
heat-air is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
