HELP (Stuck in Gear) - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 13 (permalink) Old 06-24-2006, 11:13 PM Thread Starter
My friend has a 350 Rancher ES, I'm guessing b/w 02-04. He went to load it up today to ride and it wouldn't start because it was stuck in gear. It is on a flat surface so that's not an issue. You can turn the key on and it shows the 2 "flashing" on and off. If you press the up or down buttons nothing happens. We are not the most mechanically inclined people, but if pushed in the right direction were almost dangerous! If someone has any ideas please let me know.
06 Foreman 500 ES
Perfex Long Travel
26" Bridgestone Mudhooks Xxtreme
ITP Black Delta Series
Reverse Overide
HMF Exhaust, K&N, Jetted
Ricochet Swingarm Skid
Kolpin Flat Fuel Pack
3000# Venom Winch
Tennessee is offline
post #2 of 13 (permalink) Old 06-25-2006, 07:04 AM
Honda Mechanic's Avatar
With the accessory shifter shift bike into neutral .. Count the number of flashes this is the self diagnostic code ..
Honda Mechanic is offline
post #3 of 13 (permalink) Old 06-25-2006, 02:42 PM Thread Starter
Honda Mechanic, Thanks for the info I had no idea about the accessory shifter. The Rancher has no tool kit anymore, will my shifter that came with my Foreman work? I'll have him count the flashes. I didn't count them when I was there but I think it was just flashing constantly, but I check for a pattern. THANKS AGAIN
06 Foreman 500 ES
Perfex Long Travel
Reverse Overide
3000# Venom Winch
post #4 of 13 (permalink) Old 06-25-2006, 10:35 PM
Yes it's the same emergency shifter .. Here's the flash codes for the TRX350
post #5 of 13 (permalink) Old 06-26-2006, 07:53 PM
Are these codes the same for 400 AT's and other bikes?
B
400 Honda AT
Honda Fairing
Perfex Skids
Perfex Long Suspension Travel
Front and Rear Kimpex Bumpers
Front cargo box
quickhonda is offline
post #6 of 13 (permalink) Old 06-26-2006, 08:21 PM
No the codes aren't the same for all models.. This is the TRX400FG/FGA transmission codes ..
post #7 of 13 (permalink) Old 06-28-2006, 07:14 PM Thread Starter
My buddy just called me. He got it in neutral with the emergency shifter, he said that it is blinking 3 times. Looking at the chart, 3 lines up with a problem involving the angle sensor or wiring harness. Honda Mechanic, what is the next step? Does he need to just take it in or is there something else he can do? Thanks for all your help!
06 Foreman 500 ES
Perfex Long Travel
Reverse Overide
3000# Venom Winch
post #8 of 13 (permalink) Old 06-28-2006, 09:07 PM
There are a few tests in section #22 .. This is the PDF file from the Honda shop manual ..
Download File
post #9 of 13 (permalink) Old 06-28-2006, 11:25 PM
Send a message via AIM to DrDoom Send a message via Yahoo to DrDoom
QUOTE ("Tennessee":2d9s46yw)
On the front of the engine, right side, down low you'll see a metal cover held on with 2 bolts. There WILL be wires going into that cover. It covers the angle sensor. If you feel qualified, take the cover off and remove the sensor. First clue that it might be bad is if you see "Mexico" stamped into it where the wires connect. Do a search for a post (most likely from Honda Mechanic) about the test you can do to the sensor. Wifey's went bad on her 05 Rancher right after the warranty was up. Not a real expensive part and fairly simple to change it out.
2007 Yamaha Grizzly 4x4 IRS (x2)
DrDoom is offline
post #10 of 13 (permalink) Old 07-12-2006, 04:04 AM
Send a message via AIM to Rancher08 Send a message via Yahoo to Rancher08
If its an ES shake it and shift down and that works.
2004 Honda Rancher ES 4x4 Diamond plate CV boot guards and Diamong plate front bash plate, Supertrapp IDS-2, 25" Mud Bugs
1998 Kubota B7300, Custom Guard made of Railroad iron. The ultimate grill.
Rancher08 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
