So I finally got the wife's 420 top end bored and ready to go. Bottom end is back together with the exception of the shift motor.
Is there any particular "gotcha" I need to look out for here, or do I just drop the gears on place and bolt the motor down on top of them?
I've seen people talk about putting white lithium grease on this particular component. Is that on the gears under the motor? Wasn't much in the way of grease of any sort on the gears when I pulled it apart. Maybe the PO already cleaned out the factory goop.
