Help with oil,please. - Page 2 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-18-2011, 11:58 AM   #11 (permalink)
Default
Chris B,
There is no problem mixing AMSOIL with the Polaris oil as far as causing a problem. AMSOIL is formulated to be compatable with both synthetic and conventional motor oils. However mixing does reduce the wear prevention and film strength properties of the AMSOIL. For the best results for your machine i would drain it when you get a chance and refill with the AMSOIL. It really is a great product and is used by many of the top racing teams in their two stroke engines.
Bushwhacker
2006 Rancher
http://www.ridehardsynthetics.com
Bushwhacker is offline   Reply With Quote
Old 01-18-2011, 05:39 PM   #12 (permalink)
Super Moderator
h22ate's Avatar
Default
Quote:
Originally Posted by chrisb View Post
It's not the gear oil, it is only for the premix. but maybe I'll play it safe and drain it
Ahh misread. When I had my bikes I just stuck with one oil but when I would switch, just like other said keep synthetic with synthetic and vise versa and it'll be all good.
08 Rubicon
‚——P--;===ฑ--= <-
!‚–’ฏƒนถ
http://youtu.be/U71bn4ZF4K0
h22ate is offline   Reply With Quote
Old 01-18-2011, 06:05 PM   #13 (permalink)
Honda Lover
chrisb's Avatar
Default
They are both synthetic, I was worried about the whole color thing, H22 I was hoping you would chime in, I always see you on the oil chats.I am trying to stick with one oil also. The guy I got the polaris from gave me the polaris quart the next day
chrisb is offline   Reply With Quote
Old 01-18-2011, 09:35 PM   #14 (permalink)
blue02z's Avatar
Default
I've never heard a mechanic say mixing conventional & synthetic was a good idea
you can mix oil just make sure you know what add packs with what oils are being mixed. at the question at hand i would, just to be safe and have peace of mind, run Polaris oil as it is for their machines and will be okay.
Their both synthetics but what worried me was mixing tan and red
color of oil is just a dye(ie- royal purple, which is 96% snake oil btw)
it burns out and just goes back to being same ole pretty brownish
Quote:
Originally Posted by FloatingForeman View Post
Dont Mix Oils!!!...!
just depends, gearheads commonly mix oils to gain the benifits of each seperate oil. just need to do some studying
Quote:
Originally Posted by Dawg Fan View Post
What are ya talking.....$12.00 - $16.00 in oil? I would drain it, and pour in some good clean oil, if it was me.
i agree like stated above, just to be safe.
a **** fine oil that will work in our quads besides honda and amsoil is rotella 15w40 for diesels. it is a synthetic and has great add packs and is wet clutch compatible. also deals nice with the added stress and heat
2008 foreskin with power steering
26" mudlites
homemade snorkle
tractor supply fo-14 muffler
champion 3500# winch
vented carb lines
undercoated racks, bumper and snorkle
blue02z is offline   Reply With Quote
Old 01-19-2011, 08:23 PM   #15 (permalink)
Super Moderator
h22ate's Avatar
Default
Yea you'll be fine man, no need to drain. But like we all said, when you find an oil you wanna use just stick with it and you'll be in good shape!
08 Rubicon
‚——P--;===ฑ--= <-
!‚–’ฏƒนถ
Old 01-19-2011, 08:48 PM   #16 (permalink)
Honda Lover
chrisb's Avatar
Default
Thanks guys.
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
