Rear brake drum stuck on-- Help - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 23 (permalink) Old 07-07-2012, 03:44 PM Thread Starter
Hi,wondering if anyone got suggestion or tips in getting off my rear brake drum. I have 06 500 foreman with no rear brakes/brake cam is siege. I try everthing (heat/hammer/ect)to get the cam and drum to move but no luck. So I figture if I can get the drum off I can go from there,but I think the brake is stuck on and won't let me to pull the drum off. Any help
ongoing is offline
post #2 of 23 (permalink) Old 07-07-2012, 07:43 PM
Honda Lover
hughesnp's Avatar
Send a message via AIM to hughesnp
I had to use 3 flat head screwdrivers to wedge a little at a time until it popped off, when you get it all off and cleaned up, look for the thread on here that talks about putting a grease fitting in the hole the brake cam goes through, but be careful when you drill the hole that the grease fitting won't interfere with the spring going back down all the way on the outside of the brake plate
2007 Honda Foreman 500 4x4
K&N Air Filter
Carb Mod
hughesnp is offline
post #3 of 23 (permalink) Old 07-07-2012, 07:46 PM
Honda Lover
hughesnp's Avatar
and to get the brake cam out, use a big hammer and a thick piece of wood, if you don't use a piece of wood, then the head of the brake cam will mushroom out and you won't be able to get the spring holder back on or the lever that connects to the brake cables. If it gets mushroomed out, you will have to grind the end down before those 2 things will fit back on there. hope that helps yah
K&N Air Filter
Carb Mod
hughesnp is offline
post #4 of 23 (permalink) Old 07-07-2012, 07:50 PM
Honda Lover
hughesnp's Avatar
here's the link honda rear brake fix....kinda
K&N Air Filter
Carb Mod
hughesnp is offline
post #5 of 23 (permalink) Old 07-07-2012, 08:25 PM
basfnb's Avatar
basfnb is offline
post #6 of 23 (permalink) Old 07-07-2012, 08:31 PM
Honda Lover
hughesnp's Avatar
Dang, I wish my drum would've been that easy to get off, and my brake cam was seized up something serious
K&N Air Filter
Carb Mod
hughesnp is offline
post #7 of 23 (permalink) Old 07-07-2012, 09:18 PM
basfnb's Avatar
I had to get about a 4 ft pry bar on mine. It was a bitch
basfnb is offline
post #8 of 23 (permalink) Old 07-08-2012, 09:37 AM Thread Starter
thanks all, I will give it another try
ongoing is offline
post #9 of 23 (permalink) Old 07-08-2012, 12:49 PM
Honda Lover
hughesnp's Avatar
keep trying until you get it, if it's sposed to come out it will
K&N Air Filter
Carb Mod
hughesnp is offline
post #10 of 23 (permalink) Old 07-08-2012, 02:30 PM
wydglide's Avatar
Send a message via MSN to wydglide
Quote:
Originally Posted by basfnb View Post
Great Video find!
P.M. Campbell Co Lodge F&AM #778
99Yamaha Wolverine
06 Foreman TRX500
09 Foreman TRX500 "Trail Dancer"
25" Big Horn's
Mad Dog Rear Bag
Body Armor
Bash Plate
Gamin 76CSx GPS, W/RAM Mount
Warn XT25 conversion to XT30
Glide Build Audio System
Serious case of BGD
I'm not Frugal, I'm a COB...(Cheap old B@stard)
wydglide is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
