Hello, and thanks ahead of time for any help. I have a 2005 Foreman manual shift. The splined shaft for the foot shifter took a hit and the button on the end broke off inside the gearbox. The shaft slid out. I have bought a new splined shaft and oil seal. but have no idea how to proceed to replace it. I'm not much of a gear head but I can follow instructions ( rebuilt a 2006 ford powerstroke using a Chiltons manual and its running like a champ) Is it possible for me to replace this shaft in my shop with basic tools? and is there a Chiltons type manual for the foreman? Any help would be great. Thanks
Thanks, I just got back in from the shop. Got the swingarm separated and on blocks. Had to call it quits until saturday. Looks like I have easy access to the bolts on the rear cover. Any tricks I need to know before i go any further? Thanks again so much for the help!
Try not to pull the shift shaft (the one that goes through the motor to the front) out too far or the washers might fall and you'll have to pull the front cover off.
Gear shift spindle broke off on a honda rancher 350.has the electric shift wife was riding around and got stuck on 4gear tryed to manually shift down with the tool provided and the gear shift spindle broke. How can i fix it. is there manual. Any help works.
How did you remove the button on the end mine is back behind the bolt that's hold shifter spindle in place I tryed to use a magnet but it wouldn't go in far enough?
Rich hasn't been on here in years. All the regulars are gone.
Everyone went to atvhonda.com, and there is a shop manual library availabe over there as well. Verticl Scope ruins forums. They ruined this one, and they do so to every forum they take over.
Related Threads
Honda Foreman Forums
537.3K posts
43K members
Since 2005
