Headlight and display light problem - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 18 (permalink) Old 10-04-2011, 03:31 PM Thread Starter
Honda Lover
hughesnp's Avatar
Send a message via AIM to hughesnp
I have an 07 Foreman 500 and i am having a problem with my headlights and display light. Somebody flipped it for me several months ago, so I had to get a new front bumper, front carrier, upper headlight, and ignition switch. The headlights and display light have been working fine until a few days ago. The lights where coming on after the machine was running for a few seconds, but now nothing. I have cleaned out the light switch with contact cleaner, and made sure everything was plugged up right. I have checked all the fuses, they are all good. What could be the problem?
hughesnp is offline
post #2 of 18 (permalink) Old 10-04-2011, 04:09 PM
07 foreman 500's Avatar
Send a message via AIM to 07 foreman 500 Send a message via Yahoo to 07 foreman 500
Check to see if you've got power the the light. I dont think that all the lights could be blown but check them. I'd start there.
2014 Honda Foreman 500 4X4 ES (Mine)
Stock
3,000LBS promark xt
Polaris The way out... behind a Honda Best on Earth
2000 Honda Rancher 4x4 ES (Dad's)
AMS Swamp Fox Tires
3,000lbs Promark winch
2000 Honda 90 (Brother's)
stock
Sold
1997 Honda Recon S
1998 Honda Foreman ES 450 6,100mi
2007 Honda Foreman S 4,005mi
Youtube http://www.youtube.com/burnshpfan
Flickr http://www.flickr.com/photos/68436721@N02/
07 foreman 500 is offline
post #3 of 18 (permalink) Old 10-04-2011, 04:26 PM Thread Starter
Honda Lover
hughesnp's Avatar
no power to any of the lights
hughesnp is offline
post #4 of 18 (permalink) Old 10-04-2011, 08:09 PM
Does the battery have a charge? Does the winch work? If you have ES does that work? Have you tested the switch to see if it still works? Is there any breakes in the wires? that would cause a short but there should be a blown fuse......
Stock
3,000LBS promark xt
AMS Swamp Fox Tires
stock
Sold
1997 Honda Recon S
post #5 of 18 (permalink) Old 10-05-2011, 12:00 AM
I would think it's the switch. Take it out and check it with a electric meter
Stock
3,000LBS promark xt
AMS Swamp Fox Tires
stock
Sold
1997 Honda Recon S
post #6 of 18 (permalink) Old 10-05-2011, 01:43 AM Thread Starter
Honda Lover
hughesnp's Avatar
thanks for the response, i will check the switch tomorrow and let yall guys know in case yall run in to this problem
hughesnp is offline
post #7 of 18 (permalink) Old 10-05-2011, 06:07 PM
You stated that the ignition switch was changed. You may want to check and make sure that the pink wire is connected to the ignition switch as the pink wire supplies battery to the lights. Also is it only the headlights that do not work? Do the tail lights work properly?
CalgaryRider is offline
post #8 of 18 (permalink) Old 05-09-2012, 12:56 PM
hey
Quote:
My headlights were working fine but now something was going on with the fuses, and the screen was going out, the atv was still running fine. i fixed that problem everything else is working but the headlights the tail light works fine. when i put a 30 amp fuse in the fuse box that does not get blown, when i put a 15 amp in which is the requirement for that slow, that fuse gets blown after an our of use with the atv.
jonah is offline
post #9 of 18 (permalink) Old 05-09-2012, 12:57 PM
hey
jonah is offline
post #10 of 18 (permalink) Old 05-09-2012, 12:58 PM
My headlights were working fine but now something was going on with the fuses, and the screen was going out, the atv was still running fine. i fixed that problem everything else is working but the headlights the tail light works fine. when i put a 30 amp fuse in the fuse box that does not get blown, when i put a 15 amp in which is the requirement for that slow, that fuse gets blown after an our of use with the atv. does anyone know???
jonah is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
