2003 rubicon shift and speedo problems - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 02-13-2011, 10:03 PM   #1 (permalink)
Default 2003 rubicon shift and speedo problems
Hey folks,
I have had a little mice under my barn that has wrecked havoc on my rubicon. I have already repaired the wiring harness that attaches to the frame behind the front fender on throttle side, a green connector, with a green/black, white/black wire. A black plug and the wiring harness that attaches to it....The wires have been spliced back together BUT....The speedo doesn't work and when you are driving in D1 or D2 the trannie is busy...down shifts abruptly when letting off throtle, revs high trying to find correct gear...in esp...all is fine...All fuses are good...Any advice on where to look would be appreciated!
powerstroker4u is offline   Reply With Quote
Old 02-14-2011, 10:33 AM   #2 (permalink)
Administrator
toodeep's Avatar
Default
Welcome to the forum. I would guess there is another wire somewhere they chewed. Does it give any codes (FAQ section at the top of this forum section)?
Old 02-14-2011, 04:36 PM   #3 (permalink)
rich450es's Avatar
Default
welcome to the forum , if you store it in barn use moth balls around it and near the wires thay dont like them
2000 foreman 450 es-s
the f**king pig
2500lb warn winch
foreman 450 parts for sale
pm me for info
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
