Help with Carb Removal - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 18 (permalink) Old 12-18-2010, 12:59 PM Thread Starter
I need some help trying to remove the carb. I can not figure out how to take off the throttle and choke cables.
Does anyone have a write up on taking apart the carb. I need to clean this thing out.
Thanks for the help!
07 Foreman 500
jamnjeep is offline
post #2 of 18 (permalink) Old 12-18-2010, 01:05 PM
Administrator
toodeep's Avatar
Garage
For the throttle cable there is a black plastic cover on the side of the carb with one screw holding it on. Remove that, unhook the cable from the throttle linkage and unscrew the cable from the carb.
The choke you just unscrew the plastic nut from the carb and it all pulls out. The carb heater will unplug at the wiring harness. Just follow the wires back to the connector.
1987 350D (work in progress)
toodeep is offline
post #3 of 18 (permalink) Old 12-18-2010, 01:09 PM Thread Starter
Thanks again Toodeep,
I had it runnung for about an hour this morning. It runs good with the choke on but spits, sputters and will not idle with choke off. It needs a good cleaning
07 Foreman 500
jamnjeep is offline
post #4 of 18 (permalink) Old 12-18-2010, 06:09 PM Thread Starter
Alright well I was able to get the carb off. I took the bowl off and took out the little and the big jet. cleaned them sprayed them out with cleaner and air. Then sprayed the entire carb with cleaner. It really looked pretty good, not gummy. Then put everything back together. It fired right up and idles good with or with out the choke on. BUT if I touch the throttle it dies. It will only idle. I took the carb back off and bowl off checked everthong I touch made sure it was back together right. Hooked back up and same thing. What did io do? It would at least rev up before i touched it, now just idles.
HELP Please.
07 Foreman 500
jamnjeep is offline
post #5 of 18 (permalink) Old 12-19-2010, 07:57 AM
Dawg Fan's Avatar
try draining the carb while its on the bike. It will allow some clean gas to get in there and will drain anything out that may be in there as well. Do you have fresh gas in the tank....new spark plug? Keep us updated?
09' Foreman
Half Camo / Half Tan Color
28" Outlaws
1-1/2" wheel spacers
2" Perfex Long Arm Travel Lift
HMF Utility Exhaust
Dyno Jet Kit
K&n Filter and Outerware
Home Depot Snorkle
Dawg Fan is offline
post #6 of 18 (permalink) Old 12-19-2010, 11:27 AM Thread Starter
Thanks for the advise. Yea i drained all the old gas out of tank and put fresh gas in. Also i have drained the carb several times. It has a good constant flow coming from drain line. The plug is not a new one but looks really good, I sprayed it off with carb cleaner anyway and also check that it was sparking.
I guess something must still be clogged up in the carb?? Thanks for help
07 Foreman 500
jamnjeep is offline
post #7 of 18 (permalink) Old 12-19-2010, 04:30 PM Thread Starter
So I took the carb off one more time and cleaned it again. Everthing looks really clean. But same problem, it idles great w/ or w/out choke. But if I touch the throttle (even just a little pressure on it) the engine dies right away. If I try and start it while pushing the throttle it just smokes and will not fire up. Its like its getting to much fuel and no air?? opposite from orginal problem, but I am not for sure?
I think I caused the problem! Because it would at least rev up before I took the carb off. But what could I have done wrong during reassembly? All I disassembled was the bowl, float, float valve, big jet and little jet. Is there anything that could have fallen out that I did not notice after removing the items listed? Is there anything that goes in between the needle and main jet?
07 Foreman 500
jamnjeep is offline
post #8 of 18 (permalink) Old 12-19-2010, 05:38 PM
Administrator
toodeep's Avatar
Garage
There is a seat for the throttle needle, it's held in by the main jet. You should be able to look into the carb and see it sticking up slightly.
toodeep is offline
post #9 of 18 (permalink) Old 12-19-2010, 05:55 PM Thread Starter
odeep:
So I need to remove the main jet and look in there right? The seat should be around the needle? Is it rubber or cooper?
If it was missing do you think it would cause the problems I am having.
07 Foreman 500
jamnjeep is offline
post #10 of 18 (permalink) Old 12-19-2010, 07:27 PM Thread Starter
Quote:
Took off the main jet and took a look in and all I saw was the needle. There was nothing else in there that could come out.
This must be the issue. I was pretty sure I screwed something up. Going by the local Honda shop tomorrow. I hope this is the issue it seems like the problem.
Thanks alot for all the help, Toodeep! I will post back my results.
07 Foreman 500
jamnjeep is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
