Rear Brake drum - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 12 (permalink) Old 03-29-2010, 03:22 PM Thread Starter
Rear Brake drum
Hi all,I have a small problem removing the rear brake drum. My rear brake aren't working,so I decide to clean them up (everything is seized up-brakes shoes and the spind that turns the rear shoes). Problem is- the drum is loose-move back and fort but can't get it off. Is there a snap ring needs to be remove before the brake drum can come off.
thanks-to anyone can help
2006 500 honda foreman
ongoing is offline
post #2 of 12 (permalink) Old 03-29-2010, 03:26 PM
fore man 500's Avatar
loosen your brakes up all the way. wiggle it left to right and you could hit it with a rubber mallet a few times, to break up the smuck inside. when you get it off be sure to take some fine grit sand paper to the inside where the brakes create friction sometimes it will crystalize!
fore man 500 is offline
post #3 of 12 (permalink) Old 03-29-2010, 03:31 PM Thread Starter
I have remove the linkages and everything. I can get the drum to move about 1/2 inch in and out. I try a ply bar and hammer with no luck
ongoing is offline
post #4 of 12 (permalink) Old 03-29-2010, 04:17 PM Thread Starter
I saw a diagram showing a damper ring on the back side of the drum,should it be remove in order for the drum to slide off?
ongoing is offline
post #5 of 12 (permalink) Old 03-30-2010, 03:13 AM
Honda Addict
dumb question but did you remove the cotter pin and castle nut and pulled off the hub? 6 bolts and back off the brakes. it should pop off.
05 Foreman ES
27x10, 27x12 Gators
Perfex Suspension Kit
UNI Filter, FO-14 Pipe, 170 Jet
Viper Max 3000 w/ syn Rope
CTE Shocks
05foreman500 is offline
post #6 of 12 (permalink) Old 03-30-2010, 08:40 PM Thread Starter
Yep it all off except the drum.I going to try a bigger hammer,larger vice grip and use more heat and try to get the cam to move back & fort a little-to see if I can get the brakes to release a little more.
ongoing is offline
post #7 of 12 (permalink) Old 03-30-2010, 10:58 PM
I recently cleaned my rear brakes and had some difficulty taking the brake drum off. I first used some marvel mystery oil were the drum meets the axle. I gave the drum a few taps and let it sit. The next day when the drum would not wiggle loose I took a large flat screwdriver and inserted it into the indentation in the drum and hit the screwdriver 2 or 3 times. I then rotated the drum to the next indentation and repeated the process until the drum came off the axle. I then removed both brake shoes and lubricated their mounting holes.
2005 RED FOREMAN 500 4x4 S
- AP stik gards, skidplate, hook holster
- Warn 3.0 CI Winch
- 12" ITP Delta steel wheels silver
- Maxxis Bighorns 26x9x12 and 26x12x12
2004 YELLOW FOREMAN 450 4x4 S
- AP Stik Gards
- DG Skid Plate
2foremen is offline
post #8 of 12 (permalink) Old 03-31-2010, 02:14 AM
Send a message via Yahoo to phivedizzle005
Mine did the same thing.You have to take the rear brake cable's real loose then move the cam back and forth so you can release the brake pads down alittle bit.Thats whats keeping the drum from coming off.
Phivedizzle
Honda H2 Foreman
12" ITP SS Rims
26" Kenda Executioner Tires
WARN XT 2500 Winch
SMS Snorkel System
SMS 500 Watt Audio Tube
6.5" JBL Marine Speakers
High Lifter 2" Lift
K&N Jet Kit
K&N Air Filter
HID Headlights
FO-4 Exhaust
AGM ETX14 Sealed Battery
phivedizzle005 is offline
post #9 of 12 (permalink) Old 04-01-2010, 04:15 PM
davis4494's Avatar
Send a message via Yahoo to davis4494
Run the brake cable adjustment all the way out grab the arm that they hook up too and move it back and forth to losen the brakes then try to tap the drum off.
Red 06 Foreman 500 4x4 ES
4000# Venom winch
ITP Deltas
29.5 in Swamp lites
HL fender kit
Vent lines extended
Mud slinger exhaust with snorkel kit -took snorkel off
Dyno jet
Thrid headlight switch
NGK
K&N
HL lift
HL springs
HL pull start repalcement seal
2in Intake snorkel
HL clutch kit - put in then took out
Coming soon : Turner u-joint, DGL
<a href="http://profile.myspace.com/index.cfm?fu" target="_blank">http://profile.myspace.com/index.cfm?fu ... d=37880929</a>
davis4494 is offline
post #10 of 12 (permalink) Old 04-01-2010, 05:20 PM
I had the same problem on my rubicon, i ended up having to buy an axle and rear brake assembly. i mainly just lost my patients.
lwood is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
